where and how you drill 11in. rotors
Old May 20, 2004 | 03:24 AM
bigxclumzy's Avatar
Default where and how you drill 11in. rotors
where and how you guys drill your 11in. rotors to 4x100.
Old May 20, 2004 | 05:51 AM
Benny Hinn's Avatar
Default Re: where and how you drill 11in. rotors (bigxclumzy)
I do it in my basement on a drill press with a fixture that I made.
Any competent machine shop should be able to do it for you.
Old May 20, 2004 | 06:39 AM
DA6righthand's Avatar
Default Re: where and how you drill 11in. rotors (Benny Hinn)
when you drill the rotors does that quicken pad wear?
Old May 20, 2004 | 06:35 PM
Benny Hinn's Avatar
Default Re: where and how you drill 11in. rotors (nohondayet)
Redrilling the bolt circle of the rotor will not make your pads wear faster.
Do NOT "cross drill" your own rotors.
Old May 20, 2004 | 06:46 PM
S9i1R's Avatar
My uncle cross-drilled some stock (cast) rotor and it wasn't pretty they cracked right away he recommended using some steel (not cast) blanks if you want to attempt doing anything like that
BTW he owns a machine shop so he's def. got experience
Old Dec 2, 2004 | 08:52 PM
TurboTeG4's Avatar
Default Re: where and how you drill 11in. rotors (S9i1R)
Is he talking about drilling a 5 lug rotor so it fits a 4 lug, so you can do like a big break upgrade. If so where can you get this done, such as itr rotor to fit a gsr.
Old Dec 5, 2004 | 03:18 PM
bigxclumzy's Avatar
Default Re: where and how you drill 11in. rotors (TurboTeG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Is he talking about drilling a 5 lug rotor so it fits a 4 lug, so you can do like a big break upgrade. If so where can you get this done, such as itr rotor to fit a gsr.</TD></TR></TABLE>
talking about drilling prelude rotors to fit on my eg w/ 99 si front knuckles with 99 accord calipers.
Old Dec 13, 2004 | 05:57 PM
TurboTeG4's Avatar
Where can you get a 5 lug rotor redrilled to 4 lugs?
Old Dec 15, 2004 | 05:22 PM
TurboTeG4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTeG4 &raquo;</TD></TR><TR><TD CLASS="quote">Where can you get a 5 lug rotor redrilled to 4 lugs?</TD></TR></TABLE>
20vsleeper
Jul 25, 2007 09:14 PM
Solscud007
Aug 14, 2006 04:12 AM
riceball777
Jul 22, 2003 03:49 PM
OVRsi
May 29, 2003 11:39 PM
Tom Clancy
Mar 29, 2002 08:58 AM
