Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tire psi at the track?
Old May 20, 2004 | 01:39 AM
dc2Rgirl's Avatar
Default tire psi at the track?
Going to the track for the first time...what do you guys all run for max handling on street tires? I've got Eagle F1's, I was thinking 25 psi...any suggestions are appreciated!
Old May 20, 2004 | 02:56 AM
Mr. Choi's Avatar
New User
Default Re: tire psi at the track? (dc2Rgirl)
not sure on street tires but i had mine at 34 psi front and 32psi rear on a hot 94 degree day on toyo ra-1.
thats cool pressure, hot it was around 42-44psi
Old May 20, 2004 | 03:35 AM
philstireservice's Avatar
Don't go too low on the pressure with street tires you will loose all the benefit of the speed rating and handling. I would try more in the 34-36lbs range....
Old May 20, 2004 | 03:52 AM
MattD@Stoptech's Avatar
I wouldn't run 25psi even on the street
Old May 20, 2004 | 04:34 AM
Knestis's Avatar
"Max handling" on the track is about not overheating the tread compound. Low pressures will often make this problem worse, while allowing the sidewalls to roll over, so it's typical to run higher pressures on the track than on the street.
K
Old May 20, 2004 | 09:42 AM
XR4racer's Avatar
What track?
Road course... factory pressures will be fine for you.
Old May 20, 2004 | 10:10 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2Rgirl &raquo;</TD></TR><TR><TD CLASS="quote">Going to the track for the first time...what do you guys all run for max handling on street tires? I've got Eagle F1's, I was thinking 25 psi...any suggestions are appreciated!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XR4racer &raquo;</TD></TR><TR><TD CLASS="quote">What track?</TD></TR></TABLE>
I think she's talking about the short/straight "track".
... i.e., the "strip"
Old May 20, 2004 | 10:24 AM
Weston's Avatar
As the tire's heat increases, the pressure will increase as well, so many racers start with lower than normal cold pressure for road course use.
Old May 20, 2004 | 11:00 AM
Grumpy's Avatar
New User
Default Re: (Weston)
Goodyear Eagle F1s want a lot of pressure for road course running. I ran mine at max rated cold on my 99 Camaro with good success.
Old May 20, 2004 | 11:40 AM
dc2Rgirl's Avatar
Default Re: tire psi at the track? (zygspeed)
actually I'm not talking about the strip...I'm going to Monza...
So should I keep them at around 30-34 psi?
Old May 20, 2004 | 11:45 AM
SJR's Avatar
SJR
EDIT: reading is fundamental... DOH! on me. Never mind...
89civicdx's Avatar
Monza!
30-34's good stop after a couple of laps and check the pressures after the tires get hot. Whatch the edge of the tire so its not rolling over on to the side wall.
send pics
Old May 20, 2004 | 11:49 AM
dc2Rgirl's Avatar
Default Re: tire psi at the track? (SJR)
It's not a matter of squatting on that stuff...the fact is that I'm not going drag racing! I'm going to the racetrack in Monza...
I'll post pics...
SPiFF's Avatar
SJR: Monza!
89civicdx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJR &raquo;</TD></TR><TR><TD CLASS="quote">EDIT: reading is fundamental... DOH! on me. Never mind...</TD></TR></TABLE>
Don't worry! I'm still thinking about the dump truck and trash truck thread.
b00stedbyFastrax
Jul 24, 2008 08:24 AM
Jwbetley
Oct 20, 2005 05:52 AM
redboost10
Apr 27, 2004 09:37 AM
AK94GSR
Feb 9, 2004 02:19 PM
