Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
alignment issues
Old May 20, 2004 | 01:16 AM
typeass's Avatar
Default alignment issues
If a car needs alignment, would it handle worse or the same as if the car was aligned? If the car is aligned, I know that the steering wheel should be straight but does it affect how a car handles? Thanks in advance.
Old May 20, 2004 | 02:43 AM
00R101's Avatar
Default Re: alignment issues (typeass)
It would handle worse if the car is out of alignment. How it would handle would depend on how it was out of alignment and the type of car.
All production cars, from the factory are set up to be dynamically stable. That means that the alignment is such that the wheel will have some self centering capability. While the car is moving a reasonable speed, if you push the wheel a little to the left and release pressure it will return to straight itself. Also cars are setup to understeer a bit. This is very safe. Also cars are setup to wear their tires evenly.
If a car is out of alignment you may lose all 3 of these important capabilities. A bad alignment can result in dartiness, very quickly worn tires, and a much high possibility of losing control of the car in an emergency.
Old May 20, 2004 | 06:21 AM
Crosser's Avatar
Short of race tires, alignment is one of the greatest thing to effect how are car handles.
Accord2009
Jul 19, 2017 07:56 AM
CallMeKing
Apr 20, 2012 10:51 AM
jmccalip
Apr 24, 2008 06:38 PM
rasta420
Sep 20, 2005 08:57 AM
BigBadBuford
Aug 21, 2003 12:21 PM
