Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Grease on the shock's rod???PLEASE help
Old May 20, 2004 | 12:42 AM
lDanny's Avatar
Default Grease on the shock's rod???PLEASE help
is that normal? i got these teins ss and there was grease/oily substances coming out.. the guy say that he got them checked out by tein and he said "tein said it is just the grease to help the rod from scratching," is that true? cuz i can push them down by hand even on the stiffest setting, even though its still hard... do you think what he said is true? are they blown? please help
Old May 20, 2004 | 02:46 AM
00R101's Avatar
Default Re: Grease on the shock's rod???PLEASE help (DuMa)
Pushing the rods down means nothing. Are they leaking fluid? Or is there just some grease on the rods? If they leak then there is something wrong but othewise run them till they blow. You will know when they blow because the car will ride like crap.
Old May 20, 2004 | 04:57 AM
CRX Lee's Avatar
Default Re: Grease on the shock's rod???PLEASE help (00R101)
It is not abnormal to have a trace of oil on the chrome shock rods as the seals and guide bushings that run over the rod need to be lubricated or otehrwise they will wear prematurely.
What I usually tell people is that a little moisture is okay but runs or drips is not. If you are concerned, wipe the moisture off with a rag or paper towel and see how long it takes for it to return and how much continues to come out. Trace evidence on the rod or top of the body is not a bad thing but runs, drips and puddles show a problem.
lt1guy
Jan 26, 2010 08:34 PM
K2e2vin
Jun 12, 2006 01:10 PM
MugenB16A2
Dec 1, 2003 08:15 PM
MugenB16A2
Dec 1, 2003 07:45 PM
Quetzolcotl
May 22, 2002 09:51 AM
