Type R swap from EF to EG
Old May 20, 2004 | 12:18 AM
Bictorious's Avatar
Default Type R swap from EF to EG
Alright, i have a Type r motor in my CRX right now that im thinking of taking out. I just got this car and want to switch it to an EG. Now if i do that what would i have to convert to obd1? dizzy, injectors? anything else? also the wire harness should fit right into an EG right?
Old May 20, 2004 | 05:13 AM
VTECVillain's Avatar
Default Re: Type R swap from EF to EG (Bictorious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bictorious &raquo;</TD></TR><TR><TD CLASS="quote">Now if i do that what would i have to convert to obd1? dizzy, injectors? anything else? also the wire harness should fit right into an EG right?</TD></TR></TABLE>
You would need an OBD1 distributor, injectors, ECU and an EG or DC engine harness. The EF engine harness will not be compatible with the EG chassis. Although you could salvage the necessary plugs/wiring from it if you were to use a nonVTEC EG/DX harness.
Old May 20, 2004 | 09:21 AM
Bictorious's Avatar
Default Re: Type R swap from EF to EG (VTECVillain)
Now for the wire harness. I could just like a Sohc harness right? doesnt have to be one from an LS or GSR does it? Also type r's ecu comes obd2, cant i just get a conversion harness and be set?
Coolero
Oct 14, 2011 12:02 PM
KHMERXB0I213
Aug 19, 2008 08:57 PM
jdm_h22
Feb 8, 2008 08:20 PM
roydogg
Oct 17, 2004 09:53 PM
