Endlink Rod End Seals for Spherical Bearings
I'm looking into purchasing a Progress anti-sway bar and there's the option (at least for the 97+ Prelude one) of also purchasing a set of adjustable length spherical endlinks. However, these endlinks do not seem to be teflon or otherwise sealed to prevent dirt/grime to get into the bearing shown here
http://www.imagestation.com/pi...8.jpg
http://www.imagestation.com/pi...9.jpg
So I was wondering if anyone knows of any metric rod end seals as I've only been able to find standard ones. The bolt on the Prelude rear is 12mm so there's always the possibility of getting a standard seal and grinding out the middle to accomidate the larger bolt...
http://www.bakerprecision.com/rodacc.htm
I just want these things to last w/ the least amount of noise as possible and this seems the best way to keep the dirt out of them. If anyone knows where or how to procure a set of the seals post it up!
That is unless someone can recommend a better adjustable endlink that's already sealed in the 12mm size.
Modified by TimeRacer at 1:52 AM 5/20/2004
Look here http://www.sealsit.com/rodend.asp
forsakenriceboy86
Dec 7, 2009 12:05 PM
6SPD_EK
Suspension & Brakes
Apr 18, 2008 09:07 PM
