timing belt problem?
well , im having two problems actually. first, when i press on the gas pedal, the car doesnt acccelerate right away, it pauses for a second and then goes. second, sometimes when im trying to accelerate after decelerating ( like when coming out of a turn) the car actually slows down a bit and then moves out after i step on the gas. im thinking its the timint belt and i also plan on getting a tune up. please give me your opinion on whats going on here, i appeciate it greatly.
what i meant by this is that the car slows down after i step on the gas , and then goes back to having power.
yeah, either it is in dire need of a tuneup or your timing belt has jumped a tooth.
first thing id do it check timing marks -- see if they line up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jgears »</TD></TR><TR><TD CLASS="quote">Check timing on crankshaft and sprocket. Make sure spark plug wires are snug on the valve cover and on the distr. cap.</TD></TR></TABLE>
how do i check the timing on the crankshaft and sprocket? and which belt is the timing belt and is there anyway i can adjust it by myself?
B18CYAAA
Apr 21, 2009 12:37 PM
92gs...92dx
12
Aug 15, 2007 09:31 AM
newbster
Oct 13, 2006 09:43 PM
