Dyno Results....comments welcome
Old May 19, 2004 | 08:16 PM
velocitytrends's Avatar
Default Dyno Results LSVTEC, ITB's ....comments welcome
Just got back from driving 3 hour away to get the car tuned. All comments welcome, Thanks!
Here is the set-up....
Head
B16 Head
Mild PNP
Crower 413's
High Comp Valves
Ferrea Valve Springs and Reatainers
TWM ITB's (FP set @ 43lbs)
SMSP Header
RC 440cc
Cam gears (not touch/tuned)
Block
B18B GE Sleeved 84.5mm
13.1 Comp
Crower Rods
Stock Crank
Cometic High Comp HG
Lightend flywheel
Tire
24.5 x 8 x 14 MT's w/ 15psi (for dyno)
AEM EMS
Tuned w/Wide band for a couple of hours on a Mustang Dynamometer.......
232WHP w/ 145.1 Torque
Modified by velocitytrends at 12:27 AM 5/20/2004
Old May 19, 2004 | 08:35 PM
H25's Avatar
H25
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (velocitytrends)
but the tq is awfull low for a big bore ls block. with that compression. u gotta pic of the dyno? u can make a ton of hp and not go anywhere. or make less then desirable and run really strong.. it all depends on the setup. and so many other variables. We have gotten close to your tq with a 1.8l on oem honda pistons.. 143tq. not as much hp though. you get what im saying.
Old May 19, 2004 | 08:52 PM
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (MHRacing-310)
I have a dyno graph, but i have to scan it. I have gotten simular feedback from other folks about the torque as well. We actually only spent about 1.5 to 2 hours on the dyno (didn't really keep track very well) but I was wondering the same on the torque.
Old May 19, 2004 | 08:58 PM
DefiantGSR's Avatar
nice
Old May 19, 2004 | 09:06 PM
Turbo R's Avatar
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (DefiantGSR)
nice
But the torque does seem very low
Old May 19, 2004 | 09:24 PM
asubennett's Avatar
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (Turbo R)
Is the low torque maybe because of the short intake runners on the ITB's. I have never really seen a graph comparing the same motor with a manifold versus ITb's but perhaps that is the reason for the lower torque numbers? Just a thought.
Old May 19, 2004 | 11:00 PM
MaxBoost's Avatar
New User
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (asubennett)
Take it to the track and bring us numbers.
Don't worry about dyno numbers. You were on a mustang dyno, and they can give lower hp and tq figures. If your ever near a dyno-jet pass by and do a quick 3 passes..
Either way, build sounds solid! Good luck.
Old May 19, 2004 | 11:42 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (MaxBoost)
Good numbers man, the car is done the right way
103 Octane?
Old May 20, 2004 | 12:07 AM
@ries's Avatar
Must be nice to have 232WHP w/ 145.1 Torque... good-stuff!
Old May 20, 2004 | 03:55 AM
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (tommy69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy69 &raquo;</TD></TR><TR><TD CLASS="quote">Good numbers man, the car is done the right way
103 Octane?</TD></TR></TABLE>
Car was tuned on C12, and I have to give much props to Sean @ NRG (Tallahassee) for the Dyno Time and Tune, of course Eric our lead tech for the build, Tom our sales manager for getting all the parts in and Tachyon for the head work.
Plan on taking it next wednesday to Gainsville for test and tune, will have some times then hopefully, but before that I have a video of the dyno rus and of course the dyno chart.
The Tuner even mentioned to me that it was a dynamometer and that I would pull better numbers on a dynojet, but he did great work yesterday and I appreciate all the time and effort that went into the time yesterday.
Can't wait to get it on the track!
Old May 20, 2004 | 04:19 AM
Casey's Avatar
232/145 on a freakin mustang dyno very strong motor
Old May 20, 2004 | 06:00 AM
BTW I appreciate all the great feedback and props!
Old May 20, 2004 | 06:02 AM
Here is a pic during the build.....
Old May 20, 2004 | 06:06 AM
Casey's Avatar
you definitly built it the right way for sure. hit up the 1/4 and let us know how you do. that thing should haul in a light car
Old May 20, 2004 | 07:40 AM
lube's Avatar
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (Casey)
You need to hit up a dynojet if you get a chance. A buddy of mine dyno'd at 161 on a dynojet and then went to NRG and got 196 after Sean tuned his car. He also is running slower at the track now. There was another dude from Macon that had his motor tuned there and he also supposedly made 195 and he also ran slower at the track.
I'm not flaming anyone, just telling the truth.
Old May 20, 2004 | 08:16 AM
spektrum's Avatar
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (lube)
I was thinking the same thing abouyt the torque numbers after I talked to you last night.
The car is good for atleast an 11 sec pass.
This is a completely gutted race hatch, that can't weigh more than about 1900-2000lbs.
Glad this beast is finally up and running good.
If anyone would like to see it in action....we will have it out at Gainesville Raceways in FL this coming up Wed 5/26 for it's first real run after being tuned.
Old May 20, 2004 | 08:24 AM
Soda Popinski's Avatar
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (spektrum)
Nice numbers regardless.
Old May 20, 2004 | 08:28 AM
Here is a mpeg of one of the dyno runs yesterday. 56k beware(only about 40-50 seconds)
http://www.velocitytrends.com/Videos/dynohatch.mpg
check out the guys standing on the other side of the car putting their hands over their ears. That car was screaming yesterday. It was open header of course and was tearing up ear drums while laying it down.
Old May 20, 2004 | 08:36 AM
ls95hatch's Avatar
holy ****. those are huge injectors!! awesome #'s!!! what pistons?
Old May 20, 2004 | 11:59 AM
JOEY F.'s Avatar
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (ls95hatch)
i see eric in the video!!! lol..
Welp, good luck out at the track and great numbers...hopfully an axle dont pop out this time!
Old May 20, 2004 | 12:07 PM
DefiantGSR's Avatar
what are the specs on the crower 413s? awesome numbers for a mild pnp head and mustang dyno
Old May 20, 2004 | 12:10 PM
OLM-02R's Avatar
very nice.... :D yeah keep us updated with the 1/4 thanx...
Old May 20, 2004 | 01:43 PM
Tbone's Avatar
Bad ***!!!
I'm making the same power as you with a little more tq and I hit 11.s . If your at 1900lbs your in the 11's for sure
I have found that higfher fuel pressure helps in the power dept compared to injector pulse tunning. I run mine a 50ish
Old May 20, 2004 | 02:58 PM
Default Re: Dyno Results LSVTEC, ITB's ....comments welcome (Tbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">Bad ***!!!
I have found that higfher fuel pressure helps in the power dept compared to injector pulse tunning. I run mine a 50ish</TD></TR></TABLE>
Sweet! Next Time we get some dyno time, I'll remember that! Are you running ITB's What your set-up Tbone? ::just saw the thread with your set-up! NICE!
Modified by velocitytrends at 7:42 PM 5/20/2004
Old May 20, 2004 | 03:00 PM
obd2gsr's Avatar
wow
