boost a duel carb?
Old May 19, 2004 | 05:58 PM
eeebowlahhh's Avatar
Default boost a duel carb?
was just wondering if it's possible to boost a duel carb d15b from my 88-91 jdm crx ??? if so, please post some links that i could read up on it. if not then i'll have to go with the mpfi swap.. help me out
Old May 19, 2004 | 06:33 PM
90SICRX's Avatar
Default Re: boost a duel carb? (eeebowlahhh)
I really don't have any information for you other then to do the MPFI swap, it will get you some HP and will run a lot better for turbo if you ask me. Need more fuel to get to the engine quicker. Know what I'm saying?
Old May 19, 2004 | 06:49 PM
CyniKal.Mindset's Avatar
its possible but u will need to build a pressure box around the carbs for the pressurized air to get into the carbs...butin all reality those stock carbs wont handle boost very well and ur gonna cook the motor
and as for doin a MPFI swap, good luck gathering all the fuel lines, tank, pump and then the harness etc for the injection, then u would need the ECU and then comes the basic mpfi parts
best option buy a fuel injected civic
Old May 19, 2004 | 06:50 PM
The Setup's Avatar
Default Re: boost a duel carb? (CyniKal.Mindset)
tcc wut!!!!! ^^^
(Civic On the DL right hurrrrrr)
Old May 20, 2004 | 02:50 AM
4g4drb17's Avatar
Default Re: boost a duel carb? (The Setup)
don't do it its stupid, do you know how hard it is to fiddle with a carb under boost, and you will never get the air to fuel right you'll just blow the moter and you wont be able to inter cool easily.
Old May 20, 2004 | 04:45 AM
garlic jr's Avatar
Default Re: boost a duel carb? (4g4drb17)
http://www.homemadeturbo.com
click on d15b1 and d15b2 turbo projects.
Old May 20, 2004 | 01:26 PM
4g4drb17's Avatar
Default Re: boost a duel carb? (garlic jr)
ok so you see big performance gains when you see cars thats are turbo'd and you say wow i should do that, but you don't really know alot about them. do your research on factory turbo cars like early svo's nobody likes them. if you're really good at tuning your carb then maybe but every thing changes under boost and you wont have nifty engine managment systems, i'd just do a moter swap and turbo that
Old May 20, 2004 | 02:58 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 &raquo;</TD></TR><TR><TD CLASS="quote">don't do it its stupid, do you know how hard it is to fiddle with a carb under boost, and you will never get the air to fuel right you'll just blow the moter and you wont be able to inter cool easily.</TD></TR></TABLE>
Domestics do it with no problem, it'll be fined if the carbs are tuned correctly.
Old May 20, 2004 | 03:33 PM
Default Re: boost a duel carb? (LSVTEC 91 Civic)
a stock dinky honda carb will never handle boot especially since honda made them so they arent user re-jetable...not to mention they flow like a straw...and those d15 turbo projects are on dpfi on carbs
there is a reason that nobody has done this on a lowly civic that has carbs...cuz it just wont work
Old May 20, 2004 | 04:50 PM
4g4drb17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">
Domestics do it with no problem, it'll be fined if the carbs are tuned correctly.</TD></TR></TABLE> really, i was into domestics way before i was into imports, and guess what it is a problem a big problem, most of the setups involving turbo's on domestics w/ carbs was either factory and was still a big pain in the ***, or it was done very high doller or by someone who there way around every part of a car, in and out. and they always used after market carbs. don't post if you dont know what your talking about at all
Old May 20, 2004 | 04:54 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4drb17 &raquo;</TD></TR><TR><TD CLASS="quote"> really, i was into domestics way before i was into imports, and guess what it is a problem a big problem, most of the setups involving turbo's on domestics w/ carbs was either factory and was still a big pain in the ***, or it was done very high doller or by someone who there way around every part of a car, in and out. and they always used after market carbs. don't post if you dont know what your talking about at all</TD></TR></TABLE>
No ****, I wasn't talking about a bone stock engine with a rochester. I've seen some nice setups. You're so quick to be a smartass, to you my friend.
Old May 20, 2004 | 05:41 PM
4g4drb17's Avatar
No ****, I wasn't talking about a bone stock engine with a rochester. I've seen some nice setups. You're so quick to be a smartass, to you my friend.</TD></TR></TABLE> the person who started this thread is talking about bone stock, he wants a cheap performance gain. we have all seen nice setups that doesn't mean we know alot about them, and if you have ever seen a boosted honda daul carb setup i want proof. your posts were useless to you wasting our time with your stupid posts
Old May 20, 2004 | 07:43 PM
ok, well thnx for all the input... i didnt wanna do the mpfi swap, think im just gonna go buy a d15b, boost it, then drop it in, and do the bit of wireing that is needed.
Old May 20, 2004 | 08:23 PM
if u have a carbed car its gonna take more than wiring to drop a fuel injected motor in
ur gonna need the ENTIRE fuel system from a fuel injected car + the ECU and wiring harness, bascially the whole engine bay wiring harness
wwolf771177
Jan 7, 2012 09:12 PM
So krazieY
11
Sep 7, 2009 09:17 AM
hotimportcrx
17
Dec 5, 2005 04:52 PM
89sib16
Jun 9, 2003 08:46 PM
mopar95
Feb 13, 2003 01:13 PM
