What does...
Old May 19, 2004 | 03:28 PM
CA6VTEC's Avatar
Default What does...
<FONT COLOR="royalblue"> file fit the rings mean? </FONT>
Old May 19, 2004 | 09:35 PM
IMALLSLO's Avatar
Default Re: What does... (CA6VTEC)
Do you mean end gapping a ring? A ring must be end gapped to proper spec. In between the end of the rings...they must have a certain amount of space when installed into block.
Old May 20, 2004 | 10:26 AM
CA6VTEC's Avatar
Default Re: What does... (IMALLSLO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMALLSLO &raquo;</TD></TR><TR><TD CLASS="quote">Do you mean end gapping a ring? A ring must be end gapped to proper spec. In between the end of the rings...they must have a certain amount of space when installed into block.</TD></TR></TABLE>
<FONT COLOR="royalblue"> I was under the impression that is something a Machine shop does when the assemble a block? </FONT>
Old May 20, 2004 | 05:07 PM
IMALLSLO's Avatar
You must end gap a ring while assembling the motor. This is a process a miachine shop would do if they were assmbling the entire motor.
wdissident
Nov 6, 2008 09:48 PM
jjohn6438
Honda Civic (2001 - 2005)
Dec 6, 2006 10:34 AM
