Help w/ injector cc size for ITR-------------------------
I have a 98' ITR w/ 12.5:1 compression and I just ordered a VAFC, I was told to upgrade my injectors- my question is what would you guys recomend?
I would suggest any thing from 270cc stoock to 310cc aftermarket
I mean the VAFC ain't **** got one but this hasn't anything to do with needing new injectors
well the shop that will be installing the VAFC said that i will need bigger injectors, they recommed RC's.
I was orginally going to do a hondata, but to expensive right now.
i have the same compression i went with some rc 310's since i have stock bore
if you were running witth an 84mm bore i would go with some 450's
it all depends on the hp you are going to put out
jeremy.
Oct 18, 2003 10:36 AM
