Oil in the radiator?
Old May 19, 2004 | 03:03 PM
Robster Craw's Avatar
Default Oil in the radiator?
I am working on a 98 Accord LX F23A VTEC 2.3L
I am finding Oil of some sort in the Radiator
but the Head and Headgasket are fine.
What else could it be?
thanks!
Old May 19, 2004 | 04:00 PM
-RedneckDave-'s Avatar
Working
Default Re: Oil in the radiator? (404PageNotFound Si)
Could possibly be the water pump but it is most likely a bad headgasket, and i know you said it was good but i would check again.
Old May 19, 2004 | 04:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 404PageNotFound Si &raquo;</TD></TR><TR><TD CLASS="quote">I am working on a 98 Accord LX F23A VTEC 2.3L
thanks!</TD></TR></TABLE>
Ive seen a few blocks with internal cracks. Presurizing the oil system with compressed air and watching for antifreeze to be pushed out of the radiator is the only way I know to verify it.
Old May 19, 2004 | 05:02 PM
tjohnson329's Avatar
Default Re: Oil in the radiator? (Chiovnidca)
yeah if you are sure that the head gasket is not the problem another thing could be that if the block is warpped. but if not the head gasket i would put it on a hairline crack in the block maybe. just my thought.
Old May 19, 2004 | 05:41 PM
Default Re: Oil in the radiator? (tjohnson329)
yeah, i sent the head to the machine shop..
i also heard it could be ATF in the rad.
thanks for your help guys
Old May 20, 2004 | 03:04 AM
repherence1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 404PageNotFound Si &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i sent the head to the machine shop..
thanks for your help guys </TD></TR></TABLE>
there are two lines, besides the two radiator hoses that connect to the radiatior.
i'm pretty sure that it runs to the Automatic Transmission. it could be the case the ATF is leaking into the water section of the radiator -- i think the ATF flows into the radiator for cooling, then returns back to the tranny. it could be that the problem exists within your radiator.
just a thought... $0.02
thanks
Old May 20, 2004 | 03:09 AM
Default Re: Oil in the radiator? (repherence1)
oh ya, try and do a compression test...if u have not done so already. that way, u can be certain that it is not your head gasket. i found some oil in my radiator and i was told that my head gasket was bad so i went ahead and changed my head gasket. for all i know, it may not have been the problem but no more oil in my rediator. i did not do a compression test but as i cranked the motor to Top Dead Center, i could hear air pissing out from in between the head and block.
just my 2 scents
Old May 20, 2004 | 09:13 AM
jlv55's Avatar
yeah, tranny oil goes to your radiator too. its supposed to stay at the bottom though.
Old May 20, 2004 | 03:07 PM
Default Re: Oil in the radiator? (klutch44)
now come to think of it tranny oil in the radiator is probaly it. i rember my teacher from linking tech telling me that, that is very common. He also said it will look like oil because most of the time tranny fluid is red. and when it mixes with the radiator it turns brown.
like klutch44 said the tranny fluid. good call.
I thinks these forms solve problems quicker than mechanics.
Old May 20, 2004 | 05:00 PM
thanks
Azimmer
24
May 9, 2012 02:34 PM
silent702
Feb 9, 2010 08:22 AM
killa4lyfe
Jul 12, 2009 08:06 AM
ujhonda
May 11, 2006 04:29 PM
