Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Can anyone give some insight on this aluminum jack?
Old May 19, 2004 | 12:51 PM
REFLUX's Avatar
Default Can anyone give some insight on this aluminum jack?
I did some searches for aluminum jacks and looks like many people use either Harbor Freight (backordered still?) or Craftsman
I found a 24lb AL jack
2 7/8" pad height
15" max lift height
lifting 3000lbs
off Ebay but it doesn't seem to have any name or brand attached to it.
I'm not sure if I should take the risk of buying this jack (primarily garage work, little/some track).
http://cgi.ebay.com/ebaymotors...%3AIT
On the other hand, a local shop can get me a jack made by PROFORM for ~$75 more & weighs ~38lbs.
Anyone heard of Proform & can comment?
Old May 19, 2004 | 12:54 PM
typer_801's Avatar
Default Re: Can anyone give some insight on this aluminum jack? (REFLUX)
Sam's Club also has them...they have some goofy graphics on them, but appear to be the same as the Harbor Freight ones.
Old May 19, 2004 | 12:55 PM
.RJ's Avatar
.RJ
Appears to be identical to the cheaper one sold by HF... I'm using the $130 variety available at HF, bigger load capacity, quick-pump, and higher lift height.
Old May 19, 2004 | 01:00 PM
Tyson's Avatar
i can tell the shipping box is pretty much the same as the HF one i got, which means its coming from the same factory. they say they made custom order for a lower min height, so i guess they sacrificed the max height, which i really like that my HF jack gets higher than anything else.
Old May 19, 2004 | 01:37 PM
maxQ's Avatar
Default Re: Can anyone give some insight on this aluminum jack? (Tyson)
Love my Craftsman. Built better than the $130 HF jack. Raises to 17 3/4".
It was pricey ($180) but I'm betting I'll see the return on it.
Old May 19, 2004 | 01:41 PM
slammed_93_hatch's Avatar
Default Re: Can anyone give some insight on this aluminum jack? (maxQ)
what the minimum height on the HF and craftsmen jacks
Old May 19, 2004 | 01:58 PM
REFLUX's Avatar
awesome, thanks for the replies guys
Wasn't sure if these were the same as HF jacks
I'm not doing any heavy duty work on my car in the garage but if/when that time comes and I need a better jack, I'll prbly go with an AC jack
Old May 19, 2004 | 06:48 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Can anyone give some insight on this aluminum jack? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">what the minimum height on the HF and craftsmen jacks</TD></TR></TABLE>
$140 Harbor Freight Jack (40105): 3 1/2"
$90 Harbor Freight Jack (91039): 3"
$200 Craftsman Jack (Sears #00950239000, Mfr. model #G620S): 3 3/4"
Click on links for other specs. Some require fewer pumps, some lift higher, some are more sturdy, etc.
Old May 20, 2004 | 03:51 AM
Knestis's Avatar
The next time someone wants to whine about the popularity of NASCAR Cup the street tuner import craze, think about how we have to suffer through the decision about WHICH anodized aluminum jack to buy. The factories are sure as hell not jigging up to build these things for NASA and SCCA members...
K
Old May 20, 2004 | 06:32 AM
Crosser's Avatar
Default Re: Can anyone give some insight on this aluminum jack? (Knestis)
Yes, this is the same as the smaller HF jack. I just got mine a couple weeks ago and it came in the same black box that you can see in the picture stacked below the table the jacks are on.
Inital impression of the jack. I like it very much as a jack to take to autocross events where the purpose is basically limited to changing tires. It is very light (something Jen can handle no problem). Jacks the car up quickly without having to apply extreme pressure on the handle (another necessity with Jen in mind being how light she is). However, I would not want this to be my only jack. The reason for this the the limited height that it extends to. For working on the car, this jack does not provide a sufficient height to work under the car. So, if you are looking for a jack to change tires, this is very good choice, however, make sure you have another at home when you need to work on the car.
Eric
Old May 20, 2004 | 06:41 AM
ATS*Mark's Avatar
OG triple OG
Default Re: Can anyone give some insight on this aluminum jack? (Crosser)
those jacks look similar to the jegs jacks as well , very nice jack
Old May 20, 2004 | 07:38 AM
MarkosMotorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis &raquo;</TD></TR><TR><TD CLASS="quote">The next time someone wants to whine about the popularity of NASCAR Cup the street tuner import craze, think about how we have to suffer through the decision about WHICH anodized aluminum jack to buy. The factories are sure as hell not jigging up to build these things for NASA and SCCA members...
K</TD></TR></TABLE> Well I doubt they are making them for NASCAR purpose either... since I have never seen a HF jack in a NASCAR Touring Series, Truck, Busch, or Cup Garage
Old May 20, 2004 | 10:56 AM
Knestis's Avatar
Default Re: Can anyone give some insight on this aluminum jack? (oxstarsstripesxo)
...but you don't think that there are a lot of NASCAR fans who have decided that they need an aluminum jack "just like" Chocolate Myers or one of those guys uses?
K
Old May 20, 2004 | 01:24 PM
SlapSmak's Avatar
I just purchased the Torin Al racing jack from pep boys. It is on sale for 129 and i had a credit from brake pads for 80.00, net cost 49.00. it is fast pump, like 5 to full height, very light, single piston design. I love it.
http://pepboys.crossmediaservi...=5111
Old May 20, 2004 | 02:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knestis &raquo;</TD></TR><TR><TD CLASS="quote">...but you don't think that there are a lot of NASCAR fans who have decided that they need an aluminum jack "just like" Chocolate Myers or one of those guys uses?
K</TD></TR></TABLE>
That could be... (Chocolate Myers is actually a gas man )
Old May 20, 2004 | 02:09 PM
Want2race's Avatar
Reread the add;
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
* This IS NOT a fast pump jack ... This jack was ordered with
NORMAL PUMPS to allow EASY HANDLE EFFORT !</TD></TR></TABLE>
So its not like the HF jack! Its just a light normal jack..
Old May 20, 2004 | 03:31 PM
STN_Pat's Avatar
Default Re: Can anyone give some insight on this aluminum jack? (Want2race)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ebay salesman &raquo;</TD></TR><TR><TD CLASS="quote">LIFT THE CORVETTE WITH SIMPLE ONE HAND
EFFORT SAYS IT ALL ! </TD></TR></TABLE>
hehehe
I think it doesnt seems to be bad. But its ebay
Old May 20, 2004 | 05:18 PM
Crosser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Want2race &raquo;</TD></TR><TR><TD CLASS="quote">Reread the add;
So its not like the HF jack! Its just a light normal jack.. </TD></TR></TABLE>
Actually, the smaller HF jack is NOT a fast pump jack.
Old May 21, 2004 | 04:26 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxQ &raquo;</TD></TR><TR><TD CLASS="quote">Love my Craftsman. </TD></TR></TABLE>
same here. also, it will work in a pinch i get a flat on the tow rig (suburban with open trailer) something i think the HF jacks will have a problem with.
Old May 21, 2004 | 04:32 AM
MattD@Stoptech's Avatar
Default Re: Can anyone give some insight on this aluminum jack? (rodney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodney &raquo;</TD></TR><TR><TD CLASS="quote">
same here. also, it will work in a pinch i get a flat on the tow rig (suburban with open trailer) something i think the HF jacks will have a problem with. </TD></TR></TABLE>
Wrong! The larger HF had no problems when I used it to lift the trailer up (fully loaded car on top)
vanny_david
70
Apr 15, 2010 04:31 PM
ineedhelp
Welding / Fabrication
106
Sep 30, 2008 06:30 AM
Slammd Sol
Jul 17, 2007 11:00 AM
diyer
Mar 12, 2006 01:34 PM
MaddMatt
38
Feb 26, 2005 08:15 AM
