b16 swap done. battery fuse keeps blowing
Old May 19, 2004 | 12:49 PM
coot_er's Avatar
Default b16 swap done. battery fuse keeps blowing
i put a first generation b16 into my 91 Hf. i connect the positive first and then the negative. it sat there for a second and the 60A battery fuse blew. so i check my grounds. i saw that the guy helping me connected the negative battery ground to the battery tray, so i moved it to the tranny and relplace the fuse. as soon as i touched the negative terminal it blew again. what can it be?
Old May 19, 2004 | 05:21 PM
coot_er's Avatar
Default Re: b16 swap done. battery fuse keeps blowing (coot_er)
any ideas?
Old May 19, 2004 | 05:25 PM
virginia_dude's Avatar
check your cables and harnes, I'll be you have scraped insulation and its shorting out.
primeredbeast's Avatar
check your ground to the strarter and the tranny they might be off
Old May 19, 2004 | 05:26 PM
Default Re: b16 swap done. battery fuse keeps blowing (primeredbeast)
also is it sparking when u put the negative on there?
odyssey 07
Mar 13, 2018 11:00 PM
rhd_ef8
12
Apr 29, 2007 11:27 AM
Mychal71
Sep 10, 2006 02:01 PM
DiSbaDbOi
16
Jan 5, 2005 07:24 PM
