New clutch and flywheel. Anything else while I've got tranny off??
Hi i just ordered a new clutch and flywheel and while doing the install is there anything else that you guys recommend that i change while i have the tranny off?? Should i get the ARP bolts for the flywheel?? Or are the stock ones ok. I think they make um for the flywheel or clutch or something. But my main question is, what else should i change while my tranny is off. And i dont mean new gears or lsd or anything. Things reasonable maybe for maitanance or recommended changes.
Flywheel (resurface if old, no need for you)
Clutch disk
Pressure plate
Throw-out bearing
Pilot bearing
Rear Main seal
Make sure to properly grease the needed areas using some high-temp Urea grease (pretty sure thats what Helms calls it). Might want to also consider using some Loc-Tite on the flywheel and pressure plate bolts.
IMO, that's about as thorough a clutch job as one can be.
Clutch disk
Pressure plate
Throw-out bearing
Pilot bearing
Rear Main seal
thread lock for the flywheel bolts.... would have been nice if i had remembered to use it on mine...
raidacaipo
May 9, 2009 07:21 PM
Jet Black
13
Aug 12, 2003 06:09 PM
