92 accord tranny problems "auto"
Old May 19, 2004 | 09:10 AM
toyorotor's Avatar
Default 92 accord tranny problems "auto"
tranny is stuck on 2nd and 4th gear.....its an automatic, so i have to start off on 2nd then shift to 4th gear, and the D4 light stays on.... i changed the shift solenoids on the top and bottom off the tranny with some used one from a 97 accord and it still doesnt work..... can anyone pls help???
Old May 19, 2004 | 09:43 AM
under advisement's Avatar
Default Re: 92 accord tranny problems "auto" (toyorotor)
Sounds like yo need a tranny.
Old May 19, 2004 | 08:52 PM
asf22's Avatar
hey you need a new tranny computer. try unplugging the connectors to the tranny ecu and reconnect them. if that dont help -need new tranny ecu.
Old May 19, 2004 | 09:00 PM
alb_accord's Avatar
before u do anything just get the codes from the TCU.
Old May 19, 2004 | 11:10 PM
acurarsxguy's Avatar
Default Re: (alb_accord)
I would replace the Transmission Control Module. Over the years, I seen quite a few of these TCM units go bad. In your case you say that you can start off in 2nd and shift manually into 3rd, and the tranny shifts fine. This was the same case with the 90 honda accord that I serviced last week, it was the TCM unit. Replaced the TCM unit, the problem was gone. I would look at your VSS (Vehicle Speed Sensor), problems you would see with a bad VSS is the speedo would be acting up. But if your speedo is working fine, its most likely your TCM unit.
Good Luck!
Old May 20, 2004 | 05:35 AM
toyorotor's Avatar
first, let me say thanks to all who replied...
now two more questions: where is the TCM unit???? and will a 91 or 93 TCM unit work the same???
acurarsxguy, thanks, and the speedo is working fine....
B16afmaxt
May 7, 2013 04:37 AM
redef90si
Feb 1, 2011 03:35 AM
bon3
Jun 13, 2005 10:40 AM
stevebeasley
Nov 26, 2002 06:10 AM
