Power Steering Fluid Leak
Old May 19, 2004 | 08:24 AM
sysconx's Avatar
Default Power Steering Fluid Leak
Where does the power steering fluid leak if there is no evidence of it anywhere. I need to refill it every week almost, not much, but it's always low. I checked the pump, (had it removed for a timing belt change) and there was nothing leaking from it.
Old May 19, 2004 | 09:28 AM
JimBlake's Avatar
Default Re: Power Steering Fluid Leak (sysconx)
I once had a piston seal leak inside the rack. Basically, it began filling up the air-space in the rack. Eventually, the rubber boots at each end of the rack filled up enough that I could feel what was happening.
dcarey
Jun 10, 2017 08:17 AM
stevevang
Nov 2, 2015 03:47 PM
nek0
Sep 25, 2003 08:06 AM
eL
May 26, 2003 02:58 PM
