What tires to match up with BFG drags?
Old May 19, 2004 | 06:35 AM
Pfieff's Avatar
Default What tires to match up with BFG drags?
I am going to order up a new pair of BFG drag radials today and I need to get a new set of rear tires to go with them. I was just looking for some suggestions as to what you guys would recommend for the rears and why. Preferably something in a 205/50/15. Thanks,
Pfieff
Modified by Pfieffdog at 11:43 AM 5/19/2004
Old May 19, 2004 | 09:32 AM
FerioVtec94's Avatar
Default Re: What tires to match up with BFG drags? (Pfieffdog)
toyo t1-s is probably the lightest street tire out there, only weighs 16lbs in the 15' size and handles pretty good too
Old May 19, 2004 | 12:31 PM
DIRep972's Avatar
Smarter than you
Default Re: What tires to match up with BFG drags? (FerioVtec94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FerioVtec94 &raquo;</TD></TR><TR><TD CLASS="quote">toyo t1-s is probably the lightest street tire out there, only weighs 16lbs in the 15' size and handles pretty good too</TD></TR></TABLE>
where do you find out how much tires wiegh?
Old May 19, 2004 | 12:40 PM
b18bturbo's Avatar
Default Re: What tires to match up with BFG drags? (DIRep972)
hers a start for most tires and how much they weigh
http://www.miata.net/faq/tire_weights.html
Old May 26, 2004 | 08:47 AM
96dc2's Avatar
Are you going to be daily driving with the BFG's? I wouldn't worry too much about what rear tires to get. Personally, the cheapest tire you can find should do. But be careful if the tire you choose isn't very "sticky". If you were to take a corner too fast, your rear end will come around. I have experienced this before.
Old May 26, 2004 | 09:24 AM
DIRep972's Avatar
Smarter than you
Default Re: What tires to match up with BFG drags? (96dc2)
you should pay attention to the tire's speed rating as well.. Not sure what kinda racing you do, but if you buy a cheap tire, make sure you can do well over 100mph on it.
Going Postal
Sep 28, 2006 06:42 AM
icefirezero
Jun 6, 2006 06:19 AM
ka-nife_
May 5, 2006 05:50 PM
dcx27
Mar 2, 2006 06:37 AM
daft
Jul 7, 2005 12:10 PM
