car dying out on me on the highway and backfiring,...
Old May 19, 2004 | 01:24 AM
IWearMyKswiss's Avatar
New User
Default car dying out on me on the highway and backfiring,...
tonight on the way home while on the highway,. my tach went crazy and the car kept cutting out,..when it was trying to shut off i would give it a little gas just to keep her on but the car backfired,..she would drive fine for a couple mins,..act up and then drive fun again,..backfired pretty fawking loud too,...any ideas on whats causing this? could it be my distributor?
Old May 19, 2004 | 03:25 AM
Chiovnidca's Avatar
Default Re: car dying out on me on the highway and backfiring,... (2.0 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0 EK &raquo;</TD></TR><TR><TD CLASS="quote">tonight on the way home while on the highway,. my tach went crazy and the car kept cutting out,..when it was trying to shut off i would give it a little gas just to keep her on but the car backfired,..she would drive fine for a couple mins,..act up and then drive fun again,..backfired pretty fawking loud too,...any ideas on whats causing this? could it be my distributor? </TD></TR></TABLE>
Igniter maybe?
Old May 19, 2004 | 05:47 AM
punku10's Avatar
Default Re: (Dimi)
is it hesitating and if you give it gas to get the rpms up running ok for a little bit then doing it again... this happened to me last summer it was my distributor - i changed that spark plugs and wires and it fixed it
hope that helps
Old May 19, 2004 | 06:03 AM
speedfreek128's Avatar
maybe your wire harness ground is loose....the one on the thermostat housing
Old May 19, 2004 | 06:30 AM
wooderson's Avatar
Default Re: car dying out on me on the highway and backfiring,... (speedfreek128)
I had a similiar problem, car would hesitate and backfire between 2-3000 rpms, but as punku10 stated, I changed plugs and wires and now it runs like a top.
Old May 19, 2004 | 10:57 AM
New User
Default Re: car dying out on me on the highway and backfiring,... (wooderson)
did any of you guys who had the same problem as me have trouble starting the car sometimes? ,..like sometimes it would just crank but wouldnt fire,..i would sit there for a min or 2 and try to start it up and it would fire
Old May 19, 2004 | 11:00 AM
krazn's Avatar
i had the same problem when my distributor was a bust. but i dont want u to waste money on a whole new one if that isn't the real problem. i'm just giving u my experience. hope it helps.
wooderson's Avatar
Kind of, on mine it just took a couple more cranks then what it does now before it started.
Old May 19, 2004 | 11:02 AM
shorty0o29's Avatar
Also happened to me once and it turned out that my plugs were fouled. I changed the plugs and now it runs perfect
Old May 19, 2004 | 11:18 AM
New User
Default Re: car dying out on me on the highway and backfiring,... (shorty0o29)
okay before i go purchase new plugs and wires (although i will do that anyways even though i just did a tuneup 10k miles ago) do you guys with the same problem as me have your tach jump like crazy?
Old May 19, 2004 | 11:37 AM
New User
now the car just cranks but wont fire,...i hope its just the plugs that are fouled,..i really dont want to buy another distributor
Old May 19, 2004 | 11:41 AM
Edwardo911's Avatar
I had the same exact problem a while back. My MSD ignition was failing and I reverted back to stock. Also-it may be the map sensor. I have now blown the motor and am building a new one.
-Edward
Old May 19, 2004 | 01:12 PM
New User
alright boys,..i went and got some NGK spark plugs (didnt get wires yet because nobody stocks the NGK blues around here) and i put them in,..the car started up just fine,..im guessing it was my spark plugs that were fawking me up seeing as how the car wouldnt even fire earlier,..just crank,..so verdict is,..i think the zex plugs were the culprits,..i just changed those bastards 10k miles ago,..i only ran em since i was running a zex nitrous kit,...i put the new plugs in but havent driven the car yet,..but im guessing she is going to be fine because like i said,..the car wouldnt even start earlier with the old plugs in but started with the new plugs,..thanks for the help boys
Old May 19, 2004 | 01:15 PM
TurboEH2's Avatar
i had alot of trouble with them zex plugs. i dunno why exactly but the car did exactly what u stated above. seemed weird to me. so i swapped em out for some ngk's aswell
Old May 19, 2004 | 01:43 PM
92siracer's Avatar
my car is doin the same thing rite now.....my friend said it might be the ignitior...but mine doesnt backfire....well i dont think it is cuz i got a stock muffler.
Old May 19, 2004 | 02:12 PM
Russ713's Avatar
dAng!
Default Re: car dying out on me on the highway and backfiring,... (92siracer)
check your rotor button also . It's inside the distributor
Old May 19, 2004 | 02:20 PM
jdmscg's Avatar
No Sales Forums
pull the dist. cap and check for moisture build up, hopefully it could be as easy as changing the cap and rotor. worst scenario it can be the ignitor or maybe the dist. taking a ****.
Old May 20, 2004 | 09:00 PM
92siracer's Avatar
Default Re: (punku10)
hey i changed my plugs, wires, and dizzy and it still does the hesistating, backfiring, and when i give it gas it jerks.....anyone help?
NoItsNotHerEk9
Apr 20, 2011 05:36 PM
Otherguy
10
Feb 27, 2005 10:41 PM
Sketch_hs
Sep 13, 2003 01:53 PM
crxtreme27
Apr 3, 2003 08:46 AM
