dpfi-mpfi power feed
Old May 18, 2004 | 07:22 PM
ryanplayjoint's Avatar
Default dpfi-mpfi power feed
I wasn't getting 12v to the wiring harness, so i spliced from a 12v source from an unused connectorand spliced it to the yel/blk wire on the engine harness. Now when the engine starts I can take the key out of the ignition and it still runs like the key is still in. The dash lights are on and every thing. Only when I pull the fuel pump connector does the engine turn off. I also think that the fuel pump is always pumping because i hear a hissing sound coming from the return line of the FPR. The car is a 91 STD hatchback with a ls/vtec using a dual point-to-multipoint wiring harness. Any ideas are much appreciated.
Old May 18, 2004 | 07:43 PM
civickiller's Avatar
Default Re: dpfi-mpfi power feed (ryanplayjoint)
take off the wire and see if it still does it
Old May 19, 2004 | 09:16 PM
Default Re: dpfi-mpfi power feed (civickiller)
I'll try it , But I'm thinking I will not have any fuel or spark. I'll post back thanks for the idea
BigbamaBen
Apr 29, 2012 08:11 PM
GsrTurboCRX88
Mar 13, 2007 08:53 PM
e jay one
Jan 17, 2007 09:48 AM
carbonlaced
Mar 29, 2006 04:32 PM
