MPFI wiring question
Old May 18, 2004 | 07:21 PM
dellman177's Avatar
Default MPFI wiring question
I found two versions of DPFI->MPFI wiring digrams for the injectors
here's the pic:
right now, my car is cranking but not starting, but i suspect this may be the problem...i was wondering if someone can tell me which one is the right setup.
Thanks for the help!
Old May 18, 2004 | 07:50 PM
civickiller's Avatar
Default Re: MPFI wiring question (dellman177)
the other setup is rigth, if that doesnt work try and switch the #2 and #4 injector wiring. idk my scc article conflicts each other with the wording and with the drawing so idk which one is right, i forget which one worked with me.
Old May 18, 2004 | 07:56 PM
EG8R's Avatar
Default Re: MPFI wiring question (civickiller)
Correct. "The other setup" is correct.
lildrgn2.0
Oct 27, 2003 08:39 AM
