my autox run @ california speedway may-16
hey guys, i recorded one of my runs this past weekend. leave me some tips, pointers, comments, anything...
11 megs (right click and save):
http://www.andy.iaintnothug.co...n.mpg
thanks
thanks
hmm... turbo delsol.. andy? i think you were in the same run group as me..
i was the yellow s2k in asp...
your lines were good.. for the last sweep before you went through the gates (turn2), you should have gone outward more to set you up better for the two gates which would have been a straight line.. other than that, you can carry more speed through the course..
good job.. getting good lines is key..
on a seperate note.. the course wasn't as technical as others normally are..
i cut out a small square out of 3/4" thick wood and put it in that little square we have in the middle between the two compartments. then i ran wood from that base to the dome light, and put an "L" bracket at the top to screw the top into the hole that holds in the dome light. then i attached another big "L" bracket on the side of the support and had the camera mounted to that.
i was going to take some pictures this weekend to show you, cause its not easy to visualize with words. its not pretty but it works well, i can tugg hard on it and it wont move, plus, its cheap and still removable.
ill post pictures sunday night
i took pictures of my cam mount...but my web host is down cause i went over the bandwidth limit. we can wait till i can use it again, or i can email it to you.
