Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Autopower Harness w/Rollbar on 91 CRX
Old May 18, 2004 | 05:32 PM
tunedek's Avatar
Default Autopower Harness w/Rollbar on 91 CRX
NEED HELP! Autopower does not provide instructions on how to wrap the harness around the roll bar or where to mount the lap retraints. Any help or refrences to site would be very appreciated. Thank You.
Old May 18, 2004 | 05:38 PM
.RJ's Avatar
.RJ
Default Re: Autopower Harness w/Rollbar on 91 CRX (tunedb16a)
http://simpsonraceproducts.com...g.asp
Old May 18, 2004 | 05:47 PM
travis's Avatar
The harness bar mount goes like this:
If your harness is longer, you can do the reverse of this so that the slack hangs downward from the buckle. The 91 CRX has an exhaust tunnel mount suitable for a clip-in fitting and an eye-bolt. You'll need to drill this hole on the door side on the floor and use a back-up plate for each eye-bolt. Follow the parameters in .RJ's post. The sub belt is easiest as a bolt-in with a backup plate, again following the Simpson diagram.
Old May 18, 2004 | 06:18 PM
Driven's Avatar
Default Re: Autopower Harness w/Rollbar on 91 CRX (travis)
shouldn't the harness go thru the slider minimum of 3 times?
Old May 18, 2004 | 07:26 PM
travis's Avatar
Default Re: Autopower Harness w/Rollbar on 91 CRX (Driven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Driven &raquo;</TD></TR><TR><TD CLASS="quote">shouldn't the harness go thru the slider minimum of 3 times? </TD></TR></TABLE>
Crap, you're right. I chose an old picture and it was a poor choice. To the original poster...see where the end of the harness goes through the buckle on top? Double it back over itself one more time through the buckle so that it covers half of the buckle.
Old May 19, 2004 | 05:50 AM
Another Drew's Avatar
Here's a pdf showing what Travis is talking about
http://www.racerwholesale.com/...l.pdf
vw eater
Dec 21, 2008 09:10 AM
AWD: Jeff
Honda S2000
14
Apr 19, 2006 10:52 AM
s2geezykubo
Mar 19, 2006 11:58 PM
W O T
Welding / Fabrication
48
Nov 1, 2005 09:16 AM
ATS*Mark
30
Oct 26, 2004 05:31 PM
