skunk 2 question
Old May 18, 2004 | 01:29 PM
sihatchyvtec's Avatar
Default skunk 2 question
i plan on buying a used skunk 2 intake manifold for my geezer, do i need to buy a new intake manifold gasket too? can i get one through skunk 2? thanx jim,,
Old May 18, 2004 | 01:41 PM
greaseball's Avatar
Default Re: skunk 2 question (sihatchyvtec)
yup, you'll need a new gasket. just get one from the dealer.
Old May 18, 2004 | 03:29 PM
darrinbrewer's Avatar
Default Re: skunk 2 question (greaseball)
may want to go ahead and get a new throttle body gasket also, some don't come off too easy..it's just like $5 ..change the pcv valve while your there, it'll be easier to get to..another $5-6
Old May 18, 2004 | 06:36 PM
xplanetearth420x's Avatar
Default Re: skunk 2 question (darrinbrewer)
u would reconmend a new gasket but heres everything you need to know
https://honda-tech.com/zerothread?id=682550
Old May 18, 2004 | 08:52 PM
B00ST2nR's Avatar
Default Re: skunk 2 question (xplanetearth420x)
I actually re-used my intake manifold gasket when I swapped it with the Skunk2 IM. It was still perfectly fine to use... but then again I only had 9,000 miles on the car.
You'll want to get a new Throttle Body gasket tho.
Old May 22, 2004 | 08:15 PM
Default Re: skunk 2 question (Skunk2nR)
the new throttle body gasket i got was WAY differnet and car idled funky...it was the weekend..i reused my gasket..and luckily haven't had any problems..but my intake manifold gasket was stuck on there good though
Moonraker09
Feb 13, 2013 08:50 PM
rewerbcrx
Jul 3, 2006 07:11 AM
SuperJay
Apr 20, 2005 08:20 PM
vietshinobi
Jul 10, 2004 09:26 AM
98HB
Mar 24, 2004 01:28 PM
