What size tire to put on 15"/ 7" rims on 88 crx?
Old May 18, 2004 | 12:47 PM
I3ackfire's Avatar
Default What size tire to put on 15"/ 7" rims on 88 crx?
Just would like to see what you guys think, any pics would be cool too!
Old May 18, 2004 | 12:50 PM
crx_88_si's Avatar
Default Re: What size tire to put on 15"/ 7" rims on 88 crx? (I3ackfire)
mathematically the correct size is 195/50R15.
Alot of people use 205/50R15. it just makes the tire slightly taller (like 2 mm). but adds 10mm to the tread patch.
so use 205/50R15.
Old May 18, 2004 | 12:56 PM
Mr_CRX's Avatar
Default Re: What size tire to put on 15"/ 7" rims on 88 crx? (crx_88_si)
I used to have some 15x7 momo's on my car and I had 205/50's as well.
Old May 18, 2004 | 01:27 PM
I3ackfire's Avatar
Default Re: What size tire to put on 15"/ 7" rims on 88 crx? (Mr_CRX)
being that wide, wont come in conflict with any rubbing though will it?
Old May 18, 2004 | 04:18 PM
EG8R's Avatar
205/50
Depends on how low you are.... Normally it won't rub....
Old May 18, 2004 | 04:21 PM
Mr_CRX's Avatar
Default Re: What size tire to put on 15"/ 7" rims on 88 crx? (skelly ed666)
I dont remember having any rubbing problems. I would have had some had my car been lower though, but i think thats only cause the rims I had were some funky offset so they wouldnt quite tuck under the fenders if it bottomed out.
Old May 19, 2004 | 12:04 PM
I3ackfire's Avatar
Im still stock height.
I will drop it 1.5" one day, but not for a while.
Old May 19, 2004 | 12:12 PM
APEX CRX's Avatar
I have some info from Yokohama and it reads 205/50/15 to 225/50/15 for a 15x7 rim. It also depends on the tire because some have a rounded shoulder while others are more squared off. I run 205's on my 15x7 Slips and my car is pretty low.
Old May 19, 2004 | 12:14 PM
SiRex91's Avatar
Default Re: What size tire to put on 15"/ 7" rims on 88 crx? (APEX CRX)
205/50/15 fo sho
I have them on my 15x6.5 wheels and I had to roll the rear fenders a little bit because it was rubbing on bumps.
I went from a 195 to a 205 and it made a huge difference in turn in
BTW, both tires were Azenis
Modified by SiRex91 at 2:21 PM 5/19/2004
Old May 19, 2004 | 12:20 PM
EL Vap133's Avatar
Default Re: What size tire to put on 15"/ 7" rims on 88 crx? (SiRex91)
Check this thread: https://honda-tech.com/zerothread?id=867381
Old May 19, 2004 | 12:39 PM
zeptozorro's Avatar
If you like grip, I loved my Falken Azenis when I had my car. They were 205/50R15 on a 15x7 wheel.
EM2junkIE
Honda Civic (2001 - 2005)
18
Feb 25, 2009 07:10 PM
rexfan
Mar 16, 2007 10:31 AM
LiL JoN
15
Jun 25, 2006 06:30 PM
b16powwer
Sep 10, 2002 06:31 PM
jond
Jan 27, 2002 09:02 PM
