What Injector clips with Siemans Deka injectors???
Old May 18, 2004 | 12:24 PM
SpoolnG2's Avatar
Default What Injector clips with Siemans Deka injectors???
I just put my new Siemans Deka injectors in and assumed i could use OBD1 injector clips. Anyways..i go to plug them in and the clip doesnt work for these injectors. So my question is, what injectors clips do i need ??
Thanks guys
Old May 18, 2004 | 12:26 PM
b18bturbo's Avatar
Default Re: What Injector clips with Siemans Deka injectors??? (SpoolnG2)
you need obd 0 clips or if you want ot make your obd 1 work take and exacto knife and cut the inner tab on the injector there is little tab line in it
Old May 18, 2004 | 12:31 PM
SpoolnG2's Avatar
Default Re: What Injector clips with Siemans Deka injectors??? (b18bturbo)
Thanks for the quick response viren. I did what you said and it worked perfectly. Problem solved. Thanks again!
Old May 18, 2004 | 12:33 PM
b18bturbo's Avatar
no problem. hope you didnt cut your self that **** is deadly when you working int that small location with a knife
imationdawg
Aug 1, 2009 07:33 AM
totsie7944
Apr 22, 2008 09:18 AM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
B18 CYA
Jun 23, 2004 04:15 PM
