how can i remove this
Old May 18, 2004 | 11:56 AM
B18CR-X's Avatar
Default how can i remove this
my driver side signal light doesnt work, but what screws are needed to be taken out to remove it cause i remove the ones on the outside but just wont come out.
Old May 18, 2004 | 12:02 PM
spaceman's Avatar
Default Re: how can i remove this (B16SI00)
the one in the bumper or corner light?
Old May 18, 2004 | 12:13 PM
B18CR-X's Avatar
corner light
Old May 18, 2004 | 12:19 PM
spaceman's Avatar
Default Re: (B16SI00)
what year is your car?..if its like mine an 88 than after you take out the 2 screws then you need to pull it forward or towards the front of the car cuz there are 2 arms or clips(not sure what they are called)...pop the hood and take a close look,good luck dood.
Old May 18, 2004 | 02:19 PM
B18CR-X's Avatar
thanks for your help is a 89 so its almost the same.
Old May 18, 2004 | 02:23 PM
deftones0817's Avatar
its just tight pull on the corner light harder and straight ahead...mine are always hard to pull out.
DEF
Old May 18, 2004 | 04:27 PM
Eresuncabron's Avatar
Default Re: (deftones0817)
they have sliders right?
so u hafta pull it straight forward
maat4449
Honda CR-V & Element
Jan 12, 2011 11:02 PM
londonsupra
Feb 15, 2007 11:08 AM
danno33
Dec 28, 2006 01:43 PM
Mr.Speed
May 1, 2005 12:19 PM
zakiu
Aug 11, 2001 09:19 AM
