Size of Drag Wheels for integra?
Old May 18, 2004 | 09:52 AM
ViperbitGSR's Avatar
Default Size of Drag Wheels for integra?
Trying to find what size wheels will work on a 96 GSR for slicks. I want volk drag te-37 13x8's but i dont think they will fit over the calipers. Anyone running slicks on a GSR? I have already searched and didnt find anything. Im runnin 14.8 at 93 mph, with a 2.2 60 ft, and with a quaife and Toyo T1-S i cant drop my 60 ft. It is consistant 2.2.
Old May 18, 2004 | 11:13 AM
SadisticRacing's Avatar
Default Re: Size of Drag Wheels for integra? (ViperbitGSR)
I've got the Rota's for my Crx and they fit fine on my wife's '01 GSR also.
Here's what they look like!!!
Old May 18, 2004 | 11:20 AM
project dc2's Avatar
Default Re: Size of Drag Wheels for integra? (SadisticRacing)
what size are those wheels? n where in norcal you pick a pair up >? offset? also does htese need hubcentric rings ? * better if they dont cuz my sentra has a bigger bore in the middle than standard hondas)
Old May 18, 2004 | 11:27 AM
Default Re: Size of Drag Wheels for integra? (project dc2)
The rims are 13x8's. I got them at a shop called Midnight Performance in Sac.(916-852-6887) I don't know the offset for sure but it just bolted right on, no rings needed.
Old May 18, 2004 | 11:56 AM
marieT1GRL's Avatar
those look like the panasports?... hummmm
Old May 18, 2004 | 11:57 AM
96dc2's Avatar
TE-37's will fit. "bretx0r" has them.
Do you really need to run a 13" slick? What mods do you have?
Old May 18, 2004 | 12:02 PM
Default Re: Size of Drag Wheels for integra? (ThatOneGirl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatOneGirl &raquo;</TD></TR><TR><TD CLASS="quote">those look like the panasports?... hummmm </TD></TR></TABLE>
Yeah I've had alot of people say that but there actually Rota RB's
Old May 18, 2004 | 12:06 PM
ALLMOTOR18's Avatar
i have a pair of 15" Volk Te37s for sale that I used for drag racing...
Old May 18, 2004 | 01:55 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViperbitGSR &raquo;</TD></TR><TR><TD CLASS="quote">Trying to find what size wheels will work on a 96 GSR for slicks. I want volk drag te-37 13x8's but i dont think they will fit over the calipers. Anyone running slicks on a GSR? I have already searched and didnt find anything. Im runnin 14.8 at 93 mph, with a 2.2 60 ft, and with a quaife and Toyo T1-S i cant drop my 60 ft. It is consistant 2.2.</TD></TR></TABLE>
I run 13" bogarts wrapped with 22"x8" M&H slicks. I had to buy a small spacer to clear the front of the GSR caliper. I would think the volks would be OK but I have not personaly ran them. I would go with Lenso's if you don't want to spend the $ on weld's or bogarts.
Old May 18, 2004 | 02:51 PM
Default Re: Size of Drag Wheels for integra? (96dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> Do you really need to run a 13" slick? What mods do you have?</TD></TR></TABLE>
I want to run volks, its different noone around me runs them, people got rotas, and lenzos. i want to run a 8" slick not 13".
Old May 18, 2004 | 02:54 PM
prestonpark's Avatar
how much u got the rota rb for at midnite performance
Old May 18, 2004 | 03:02 PM
skunked's Avatar
I want to run volks, its different noone around me runs them, people got rotas, and lenzos. i want to run a 8" slick not 13".</TD></TR></TABLE>
I think he was refering to the rim size (13"), not the width.
Old May 18, 2004 | 05:18 PM
Default Re: Size of Drag Wheels for integra? (skunked)
Why would running a 13 be worse then running a 14... I thought if anything, a 13 would be better due to weight savings...
Old May 18, 2004 | 06:41 PM
13's is also better due to the sidewall....
If I remember right the price for the Rota's was around $250 but my wife bought them from me so not sure.
Old May 18, 2004 | 10:05 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViperbitGSR &raquo;</TD></TR><TR><TD CLASS="quote">Why would running a 13 be worse then running a 14... I thought if anything, a 13 would be better due to weight savings...</TD></TR></TABLE>
Running a 22x8x13 is better when you have too much power for a 20x8x14. If you don't have the power to push it, you'll just bog. Yes weight savings is a plus also.
As I asked earlier, what mods do you have and power/torque are you pushing out?
Old May 19, 2004 | 10:33 AM
As I asked earlier, what mods do you have and power/torque are you pushing out?</TD></TR></TABLE>
I/H/E, Type R cams, Type R ecu, Unorthodox Pulleys, Quaife Lsd... Clutchmasters flywheel, and Stage 4 Clutch - (Future Turbo Setup- Just getting ready) No numbers for power or torque
Running 14.8 at 93 mph with a 2.2 60ft...
Old May 19, 2004 | 11:32 AM
96dc2's Avatar
I think the majority will agree that a 22x8x13 will be too much for the power level you're at right now. I use a 20x8x14 and I have I/H/E only in my GS-R and cut 2.0xx 60 ft's. When you're turbo, though, you'll probably outpower the 20's.
There are people who run 13" slicks on a bolt-on's GS-R, but have that motor in a lighter chassis. A heavy Integra might put too much stress on the axles.
Old May 19, 2004 | 12:36 PM
skunked's Avatar
I would run the 22". I ran the 22" with my little B16 in my teg and hit consistant 1.8's with a 13.9 et. The 20's don't give enough bite...just my 2 cents.
Old May 19, 2004 | 01:26 PM
94gsr4dr's Avatar
13X8's here, but in 24.5. With your power i would use 22X8X15, which i happen to have for sale. PM me.
Old May 19, 2004 | 02:09 PM
skunked's Avatar
Default Re: Size of Drag Wheels for integra? (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">13X8's here, but in 24.5. With your power i would use 22X8X15, which i happen to have for sale. PM me.</TD></TR></TABLE>
Why go with a 15" with less bite? Doesn't make sense buddy.
Old May 19, 2004 | 02:51 PM
94gsr4dr's Avatar
I was referring to the original poster, sayin that he might have too little power at the moment for the 13's, and that the 15's might better suit him.
Old May 19, 2004 | 03:52 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">I was referring to the original poster, sayin that he might have too little power at the moment for the 13's, and that the 15's might better suit him.</TD></TR></TABLE>
Me too. He also said above he wanted to get a turbo therefore the 13" would be better for him.
Old May 19, 2004 | 04:31 PM
SpyLude92's Avatar
I was wondering if anyone has ever seen 12 inch rims, or know of 12x8 rims? I have 4 23.5x8.0 R12's A guy gave them to me. I don't even think they would fit over the brakes. Let me know if you have ever seen any 12x8 Rims. These are Michelin tires, I have had them laying around for a while.
Old May 19, 2004 | 04:37 PM
94gsr4dr's Avatar
Default Re: Size of Drag Wheels for integra? (SpyLude92)
I should probly learn to read, i didn't even realize he wanted to go turbo, and in that case just get the 13's now.
Old May 20, 2004 | 12:33 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyLude92 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if anyone has ever seen 12 inch rims, or know of 12x8 rims? I have 4 23.5x8.0 R12's A guy gave them to me. I don't even think they would fit over the brakes. Let me know if you have ever seen any 12x8 Rims. These are Michelin tires, I have had them laying around for a while. </TD></TR></TABLE>
Are you sure those aren't road racing slicks?
