Different Air Intakes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">On the new Forum Rules, if you are going to state "Search", you'll need to provide links to answer the original poster's question.
What new forum rulse that rediculous.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forum rules »</TD></TR><TR><TD CLASS="quote">
14. If the post is reported to a moderator, and you post in the thread you must give a reason.
The moderators have been getting an overwhelming number of reports with no reason other than it has been covered, and do not have time to search for threads to help the posters find what they need. If you report it as a “repost”, at least direct them down the right path. From now on "search *******" or anything of this sort without posting a link will get points docked immediately.</TD></TR></TABLE>
just czu i'm bored.....j's racing (or replica) is one of the best short ram intakes....and aem (V2) is one of the best cold air intakes.
now think about the names....SHORT ram...means the tube is much shorter, it will sit right behind the passenger headlight.....COLD AIR, means just that aswell. since the air in the engine bay tends to be warm, teh tube has an extension that actauly curves and goes down kindof under the engine bay, and the filter is actualy "outside", sits right between the friont bumper and tire (passenger side). that's the most detail you'll get out of this generous bastard
Short Ram a big upgrade from an OEm intake but it still draws in all the hot air from the enigine bay.
Cold air is better because it draws in the cold air from in front of the wheel well.
There is a danger though of using cold air intakes as you can suck water up your intake tube if you drive through a puddle or something.(then your motor will experience hydro lock- fatal to the motor)
<U>I think</U> though that short Ram produces better torque numbers than cold air
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Indeed, but I got warned by Mr. BauleyCivic for this one, so I'm just passing it on.</TD></TR></TABLE>
You shouldn't have to search for someone else because they are to lazy.
But at the same time why even post let them flownder till they figure out how to use the search button. But then you are going to have a bunch of people bumping there which intake is better threads, because no one will help them.
kekekekevin
17
Sep 9, 2006 06:48 AM
