Bride Zeta II w/ stock seat belts?
What kind of brackets and rails should I use?
Anybody have any pics of how this works?
I dont' have any plans for a rollcage, so 5-point is out of the question.
Thanks,
Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruzersi00 »</TD></TR><TR><TD CLASS="quote">What kind of brackets and rails should I use?
Thanks,</TD></TR></TABLE>
Why not buy Bride brackets and rails?
I wasn't sure if Bride brackets and rails had a spot for the seat belt mount.
I also wanted to see how the seat belt fits over the lap area.
The belt fits over the lap area just fine.
However be careful of the shoulder support as the top portion of the seat belt has a tendency of rubbing against the fabric which will cause it to wear prematurely.
And if you dont have plans for a cage, than a 4pt will cut it, not certified or approved worth a penny in any kind of racing, but it does the job...half *** tho
-Arno
Where in CA are you located?? your car seems very famililar??? (PM me if you dont want to disclose that info
Modified by 98itR484 at 10:52 PM 5/18/2004
-Arno
)Modified by 98itR484 at 10:52 PM 5/18/2004
Any tips for mounting the stock seat belts.
There is lip on the stock seat belt that prevents the seat belt from mounting flush, or vertical for that matter.
DSMpolska
Sep 15, 2008 04:24 PM
suprmods
19
Oct 21, 2005 12:07 PM
TurboIntegra
Sep 4, 2001 10:47 PM
