Top Dead Center markes......
Im doing my timing belt on my 88crx si. I want to know is there any markes to show where to line up the crank? I know their are markes on the pulley, but are their any markes to look at when the pulley is off.
I have the cam sprocket lined up to Top Dead Center, and I just want to make sure I am lineing up the crank pull to Top Dead Center, so the timing belt wont be a tooth or 2 off.
can anyone help?
Thanks
Craig
can anyone help?
Thanks
Craig
The only marks that you will be able to look at is the grove in the crank shaft exiting the motor, you will only be able to make a mental note of where the white mark on the pully is comparred to the grove in the shaft
good luck
good luck
