****did b16 swap need help****
Old May 18, 2004 | 05:59 AM
wpgcivic's Avatar
Default ****did b16 swap need help****
i did the b16 into my ef and i have a few issues
erratic idle from like 1000-2100 when warm and cold(checked fitv, eacv, vacuum lines)
temperature gauge doesnt work but the rad hoses are hot(works sometimes)
at start up revs at like 3000
lemme know, thx
Old May 18, 2004 | 07:13 AM
limpy's Avatar
Default Re: ****did b16 swap need help**** (wpgcivic)
I had have a b16 in my rex and i hd the same 3000rpm idle problem. take off the fase idle sensor that is below the throttle body (3 10mm screws) and turn the white cap with the slots in it all the way down and then back out 1 1/2 turn will idle perfect at 1100 when cold. as for speratic idle i don't know. but that should fix half of your prob.
Old May 18, 2004 | 07:41 AM
d.str0y's Avatar
did you swap the outter wires on the tps sensor?
Old May 18, 2004 | 10:29 AM
wpgcivic's Avatar
thx for the help i will try this out
Old May 18, 2004 | 01:45 PM
wpgcivic's Avatar
ok i fixed the fitv and at cold there is no erratic idle and the idle is good but when warm it the fluctuating idle starts up...
Old May 18, 2004 | 07:06 PM
d.str0y's Avatar
no codes?
Old May 18, 2004 | 08:27 PM
wpgcivic's Avatar
no codes at all, tomorrow morning i am going to change the eacv completely, ill let you guys know in the morning, later all
Old May 18, 2004 | 09:33 PM
peiku's Avatar
Default Re: (wpgcivic)
did you bypass your coolant? my crx with d16z6 converted to obd1 did that when i bypassed the coolant. when i hooked it back up it ran fine.
Old May 19, 2004 | 06:09 AM
wpgcivic's Avatar
Default Re: (peiku)
no i didnt, and i changed the eacv and it still does teh same thing so i am going to screw around with the tps for a while tonight...i am almost out of ideas
Old May 19, 2004 | 06:02 PM
wpgcivic's Avatar
well than, lol, turned out that my throttle body gasket was **** and torn, thx a million for the help guys
00trdtaco
Nov 10, 2009 02:13 PM
jdmstyleg
Oct 15, 2009 06:55 PM
jdmeg61
Oct 12, 2006 07:33 PM
jarvis199
Sep 15, 2005 06:26 PM
spaceman
Apr 19, 2004 08:48 PM
