Can overfilling your oil cause the engine light to come on?
Old May 18, 2004 | 04:30 AM
integraboi1010's Avatar
Default Can overfilling your oil cause the engine light to come on?
I think I've overfilled my engine oil and just this morning I the check engine light came on.
What should I do now?
Old May 18, 2004 | 04:41 AM
furious94ls's Avatar
Default Re: Can overfilling your oil cause the engine light to come on? (integraboi1010)
You think? Go pull the dipstick out. It should be inbetween the 2 dots. Full is at the second dot. If you are over then drain the oil out. Depending on what engine you have 4 or 4.2 quarts fills it. Pull the code for the CEL and see what it says.
Old May 18, 2004 | 05:04 AM
Professor X's Avatar
Exactly! You don't want to drive around with too much oil. Drain it as soon as you can and make sure it has the proper amount. Good luck!
Old May 18, 2004 | 05:13 AM
turbotegrar's Avatar
definately drain some out to the right amount, if you overfill you can blow seals and everything else, could be really damaging.
kmcgillic91
Jan 23, 2011 07:47 AM
mraza
Aug 1, 2006 11:24 PM
shraz
13
Jun 8, 2006 08:11 PM
36Chambers
Aug 20, 2002 05:33 AM
