all d series 92+ civic use same shift linkage?
Old May 18, 2004 | 01:49 AM
s73's Avatar
s73
New User
Default all d series 92+ civic use same shift linkage?
i am doing a auto to manual swap on my 97 civic ex 2dr....
i got two sets of shift linkages....one off a 94 cx hatch (for sure, i took it off the car myself), and one off of a 96 ek hatch (unsure...got it off someone used).
the two linkages looks different from each other....but they are both from d series motor/trannys....
my question is, do the 92-00 d series civics used the same shift linkage? because they look very different...
please let me know, thanks
Old May 18, 2004 | 04:46 PM
s73's Avatar
s73
New User
Default Re: all d series 92+ civic use same shift linkage? (s73)
bump
Old May 18, 2004 | 09:48 PM
peiku's Avatar
i am thinking that they use the same one. if you think about it, swapping a bseries in a civic, you have to use a bseries shift linkage. if that linkage can fit in a 92-95 and it fits in a 96+, it should be the same.
Old May 18, 2004 | 10:24 PM
Whitfield Inc.'s Avatar
88-91 is all by it's self - 92-00 is the same in the way they work and bolt in but you are right they look different. They are different because the way the EK heat shield sits.
Old May 18, 2004 | 10:27 PM
Old May 19, 2004 | 12:34 AM
s73's Avatar
s73
New User
Default Re: all d series 92+ civic use same shift linkage? (RageDzine)
so does that mean that inorder for it to work (w/o rubbing the heat shield) i need to use a EX linkage, or i will be fine with a DX hatch linkage?
Old May 19, 2004 | 10:01 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
as rage said the 92-00 single cam linkage is the same you should be fine with anyof them
PRDM
Jun 22, 2009 12:26 PM
onefastefhatch
Mar 8, 2006 12:23 AM
s73
May 18, 2004 07:18 PM
jdmlife
May 11, 2004 01:13 PM
