tranny / clutch problem? .... take a look.
Old May 17, 2004 | 11:19 PM
7808's Avatar
Default tranny / clutch problem? .... take a look.
my car goes into gear kinda rough somtimes... and third usually grinds a little.
its a 90 civic DX hatch 5 speed. take a look and let me know what you think is wrong this part apeared to have oil dripping off it..
Old May 17, 2004 | 11:20 PM
civickiller's Avatar
Default Re: tranny / clutch problem? .... take a look. (fuctup)
when was the last time you changed your tranny fluid ?
Old May 17, 2004 | 11:54 PM
7808's Avatar
Default Re: tranny / clutch problem? .... take a look. (civickiller)
dont know, but i can tell you forsure it hasent been done it 2 years.
i think im gona have to do it when i replace the axel in the next few days.. what kinda oil do i use anyways?
Old May 18, 2004 | 12:16 AM
i would recommend doing that first and see if it helps at all
well i would say either regular 10w30, honda mtf, or gm syncromesh friction modified. theres a big debate on which one is the best.
how is the shifter, does it have alot of play in it ?
Old May 18, 2004 | 03:59 AM
crx_88_si's Avatar
I used Honda MTF, made a big difference.
Old May 18, 2004 | 05:39 AM
1st-hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">dont know, but i can tell you forsure it hasent been done it 2 years.
i think im gona have to do it when i replace the axel in the next few days.. what kinda oil do i use anyways?</TD></TR></TABLE>
Honda MTF has been known to help with some of the grinds that we get on our old trannies.
Old May 18, 2004 | 07:14 AM
spyz34's Avatar
Default Re: tranny / clutch problem? .... take a look. (1st-hybrid)
My tranny grinds when I shift hard into second and makes a nasty sound sometimes when i go into reverse. anyone else have this problem?
Where can i get this Honda MTF. How much is it?
Old May 18, 2004 | 08:21 AM
1st-hybrid's Avatar
Default Re: tranny / clutch problem? .... take a look. (spyz34)
Any Honda dealer will carry it. Prices will vary a bit most likely.
Old May 18, 2004 | 08:26 AM
EFSiR's Avatar
change the bushing on the shifter seal. Good luck with the PITA pin.
Old May 18, 2004 | 08:46 AM
B2FiNiTY's Avatar
Default Re: tranny / clutch problem? .... take a look. (EFSiR)
Definately change the fluid with good ole honda MTF.
Old May 18, 2004 | 10:52 AM
b16_madman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">change the bushing on the shifter seal. Good luck with the PITA pin. </TD></TR></TABLE>
Haha, a trick I learned was when you knock the pin out with some tap thing, put a rag on the top of it to catch the pin with it, that way you don't have to use a new one, but you may want to get a new one anyways.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyz34 &raquo;</TD></TR><TR><TD CLASS="quote">makes a nasty sound sometimes when i go into reverse. anyone else have this problem?</TD></TR></TABLE>
Sounds like just the normal nasty straight into reverse honda sound, try goin into fourth, then reverse.
Old May 18, 2004 | 10:56 AM
EL Vap133's Avatar
Since your tranny grinds, use GM syncromesh, it works wonders. Make sure you change some of the seals, maybe the fluid is leaking?
Old May 18, 2004 | 05:21 PM
7808's Avatar
Default Re: tranny / clutch problem? .... take a look. (EL Vap133)
thanks for the info..
if i shift hard my whole car shakes hard into gear.. its abused. what is that shiney metal part that goes around the thing you can see? mine looks f'ed up. i got the nasty into reverse and 3rd grind. im gona change it when i put my axel in. how much is honda mtf?
Jet Black
Sep 21, 2005 05:27 AM
ek2drproject
13
Mar 9, 2005 06:05 AM
madcrossover
17
Sep 30, 2004 08:36 AM
vmm
Jun 25, 2004 10:27 AM
743power
Oct 9, 2003 11:41 PM
