Will my car 'turn over' without a distributor?
Old May 17, 2004 | 10:56 PM
FritzInTN's Avatar
Default Will my car 'turn over' without a distributor?
Well I'm having problems tracking down all my wiring woes after swapping in an OBD1 sohc vtec swap into my OBD EK hatch. I've rewired the distributor however when I go to turn the car over, the entire electrical system dies. I have to undo the ground on the battery and give it another shot. Same thing.
So if I were to unhook my distributor wiring it should at the very least engage the starter and have the motor turn over and spit fuel correct?
Any ideas on why the electrical system dies? I have the motor grounded on the head and transmission.
Old May 18, 2004 | 01:09 AM
92b16vx's Avatar
Your engine can crank with no spark, but it won't fire, if that's what you're asking.
Old May 18, 2004 | 05:18 AM
JimBlake's Avatar
Default Re: Will my car 'turn over' without a distributor? (FritzInTN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FritzInTN &raquo;</TD></TR><TR><TD CLASS="quote">So if I were to unhook my distributor wiring it should at the very least engage the starter and have the motor turn over and spit fuel correct?</TD></TR></TABLE>The starter will turn the engine over, but I don't think the fuel injectors will fire. The ECU won't fire them without the timing signals from the distributor.
Old May 18, 2004 | 08:50 AM
PHiZ's Avatar
Default Re: Will my car 'turn over' without a distributor? (JimBlake)
I think we're confusing the terms "crank" and "turn over"
-PHiZ
jdmkidUK
Nov 30, 2011 05:49 PM
jsou
Jul 5, 2005 02:26 PM
FritzInTN
May 18, 2004 02:59 AM
aut0tek
Oct 5, 2002 09:56 AM
