Will 95 gsr oil pan fit on B18A (DA Tegs) with no probs?
My pan is ultimately hammered after hitting a rock on the road. I tried switching the gasket, with correct torquing specs obviously, and it still leaks. I'm trying to hunt down the problem with my oil light and avoid changing the oil pump (no I am not driving the car). I've ran clean oil and never ran it low so I don't see whats the problem with the pump. Anyways, I found a deal here in hawaii for a clean gsr oil pan for $25. I was wondering if I will run into problems when using this pan? - I've searched - Noticed the oil pick up for VTEC motors are a little longer and the pan is a little deeper? So yeah did anyone run one without problems?
