Nothing is coming out of my Gauge Cluster
I have been working on this problem i have with my gauge cluster. I got a new dash and i removed my gauges, and wire harness and installed the new dash with my original harness, and gauge cluster. Now i have no gauges at all, i checked the fuses, installed a friends DX cluster, still nothing, took the dash out and looked at the wire for a split, nothing there also. I dont know what to do next, I read a few forums and someone said if i have a bad ground on the taillight it would effect the gauges. Could it be a light out, relay, me being dumb, what. If anyone know what i am going through i would appreshiate the help, Thanx
from my knowledge, there is no relay to the gauge cluster, so you should worry about your fuses, connector problems, missing grounds, or missing power sources...try putting a test light to the fuse that runs through the gauge cluster and see if your getting any power source
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastontheturns »</TD></TR><TR><TD CLASS="quote">search ive found lots of info on dash wiring</TD></TR></TABLE>
Why don't you post the links then so it's not like the blind leading the blind?
If you are having an electric problem that bad you will need a helm manual and you will have to individually check that harness according to the manual to find out where to trace your problem.
There is not much more to tell you other than that.
Blazin Civic
Jun 21, 2004 10:24 AM
