B16A2 Throttle body On DOHC ZC WRITE UP DIY 56k go order dsl and come back.
Old May 17, 2004 | 09:43 PM
t0eKnEe's Avatar
Default B16A2 Throttle body On DOHC ZC WRITE UP DIY 56k go order dsl and come back.
I been looking to upgrade the throttle body on my zc for the longest time but everytime I looked it up, I would get answers like no way and some say maybe and ehh a little of everything. So i decided to try it out myself and see if it worked or not once and for all. I read that the 92+ d-series motors can use the b-series throttle bodies and remembered that my motor was an OBD1 motor when i first got it and figured why would the ZC be any different.
So this is what I got: "bling bling"
Now here is my ZC one:
If you look at them both, the mounting holes look the same. Thats what made me go thru with this, I did a search for b-series throttle bodies all over the net and saw that the mounting holes looked very similar, or the same at that.
Here they are side by side:
Now and not least "The Verdict"
Hope this was useful to you ZC owners out there.
Old May 17, 2004 | 09:49 PM
t0eKnEe's Avatar
Default Re: B16A2 Throttle body On DOHC ZC WRITE UP DIY 56k go order dsl and come back. (t0eKnEe)
what a puny throttle body
Old May 17, 2004 | 09:50 PM
JapanExpress's Avatar
so on an OBD0 ZC motor, this is not an option?
Old May 17, 2004 | 09:52 PM
t0eKnEe's Avatar
Default Re: (JapanExpress)
nope, OBD0 dohc zc cannot use a b-series throttle body. Uses same mounting holes and 88-91 civic/crx.
Old May 18, 2004 | 03:45 AM
-16V-'s Avatar
Default Re: (t0eKnEe)
Cool
I'm doing the same, but with a LS TB and a Y8 IM...
How does it feel now????? Throttle response,rpms, ect ect.????
Old May 18, 2004 | 11:28 AM
t0eKnEe's Avatar
Default Re: (-16V-)
I have to pick up the throttle body gasget today first before I mount it on. I also have to port match the IM, anybody ever done that with the manifold still attached to the motor?
Old May 18, 2004 | 11:41 AM
Nocturnal_Lude's Avatar
to be safe I would take off the IM you dont want any of that particles of shavings whinding up in your combustion chamber...
honda_coupe
Mar 10, 2009 03:50 AM
909ej195
Jan 19, 2007 06:29 AM
Crx-Racer4Life
Oct 31, 2006 06:36 PM
