Can I use a peak and hold injectors (obd0 2nd gen integs) with my stock obd2 ecu???
sup eveyone!.... I installed a resistor box in my 96 gsr when I had my turbo setup. Now I am putting her back in stock but I dont want to mess with the resistor wires anymore, so I ask my friend if I can have his stock injectors from his 91 integra ls (obd0).... I know they are peak and hold because I used a resistor box from a 91 integ
. Please correct me if im wrong.
So here is my real question:
Will I be ok if I use my stock obd2 ecu with those injectors (obd0) so I dont have to mess with the resistor box OR do I really have to take out the resistor box and put them back the way they are (stock)????
Any help will be appreciated
TIA!
. Please correct me if im wrong.So here is my real question:
TIA!
You can run the injectors with any ecu you want just fine as long as you have the resistor box wired to them.
Thank you sir!
I'm just making sure... its better to be safe than sorry
dsturch1
Jul 5, 2010 09:11 PM
immorality
May 24, 2008 03:46 PM
blackntegra
Oct 29, 2006 11:49 PM
Power Rev Racing
May 20, 2005 10:20 AM
