Questions on busted timing belts...
Old May 17, 2004 | 08:23 PM
JokerTypeR's Avatar
Default Questions on busted timing belts...
My D15, bone-stock, fresh rebuild about 10K ago and 197K overall blew the belt today. I hear there's a good chance of it bending my valves. Anyone have any accurate opinions, experience, or ideas on this? The head and everything's comin' off ASAP (work is a bitch) but I'm curious how deep in I am. I wish I could do the overall swap to B16, but money...again...is a bitch. Anyone know how hard it is to get in there for this or what kind of time frame I'm about to get in to? Any words would be greatly appreciated...
Old May 17, 2004 | 08:24 PM
B2FiNiTY's Avatar
Default Re: Questions on busted timing belts... (JokerTypeR)
Definately a very high chance of bent valves. Bad news indeed.
Old May 17, 2004 | 08:28 PM
EL Vap133's Avatar
With the right tools, it isn't too hard. Just use a little muscle.
Old May 17, 2004 | 08:30 PM
JokerTypeR's Avatar
Default Re: Questions on busted timing belts... (EL Vap133)
Well this really sounds like it blows. LITTLE muscle? Aren't we talkin' like a...500lb engine w/ all back? Unless I get jacks, LoL. But hey, who does it the un-manly way? LoL.
Old May 17, 2004 | 08:33 PM
EL Vap133's Avatar
It's only a timing belt change, not a motor swap.
Old May 17, 2004 | 08:45 PM
JokerTypeR's Avatar
no no, just like...a little blowage. Ya know... I ain't got time for it, but it's gotta be done. 'preciate it ya'll.
Old May 18, 2004 | 09:51 AM
Rusty Shackleferd's Avatar
I broke a t-belt on a d15 motor and didnt hurt a thing. Throw a new belt on that bitch and be on your way.
Old May 18, 2004 | 10:02 AM
EL Vap133's Avatar
Default Re: Questions on busted timing belts... (Rusty Shackleferd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rusty Shackleferd &raquo;</TD></TR><TR><TD CLASS="quote">I broke a t-belt on a d15 motor and didnt hurt a thing. Throw a new belt on that bitch and be on your way. </TD></TR></TABLE>
Yeah, same thing on my Teg. Sometimes you get lucky.
Old May 18, 2004 | 10:03 AM
4crx4me's Avatar
Blew the timing belt on my D16A6 at 70mph. Lots of bent valves. Big ticket repair bill from Honda. That's what convinced me to start doing my own repairs again, after a lay-off of a couple of years. It only took Honda 3-4 days to get the car back to me, which I guess is a good thing. Considering they charged me over $2500.00 to do it Do it yourself save 2.5K.
Old May 18, 2004 | 10:53 AM
EL Vap133's Avatar
Default Re: Questions on busted timing belts... (4crx4me)
Ouch!! For $2500 I would rather get a B16.
Old May 18, 2004 | 10:56 AM
crx_88_si's Avatar
what were the revs on the engine when it broke? higher revs = more chance u bent valves
Old May 18, 2004 | 11:36 AM
4drEF's Avatar
Keyboard Humorist
I broke 4 timing belts on my D15 before I gave up on it. I never bent a valve. I was never going very fast (D15) so I guess that's the reason why I got lucky.
Old May 18, 2004 | 04:20 PM
JokerTypeR's Avatar
Default Re: Questions on busted timing belts... (4drEF)
Uh...I was probably 3/4 the way through third, and had just shifted to fourth. I had power all the way through third, and when I let out the clutch in fourth is when I lost power. I thought maybe I'd lost fuel to the engine so I tried to "rolling-jump" it once or twice, obviously no response. One question though. Bustin' this thing apart tongiht, I encountered that the bolt to get that pulley off the crank to reach the T-belt is on there like..welded, I swear, I can't bust it. Tried an electric and air impact wrench on it. Is there some trick to it? Is it reverse-threaded maybe?
Old May 18, 2004 | 04:25 PM
Mr_CRX's Avatar
It's not reverse threaded, at least not on my b18c1 its not. its just a b*tch to get off. good luck
I used an impact gun with 150 psi and had to beat on it for a while. Theres a ton of stuff in the archives about the crank pulley bolt.
Old May 18, 2004 | 04:54 PM
JokerTypeR's Avatar
Default Re: Questions on busted timing belts... (Mr_CRX)
Where can I find these archives? Are they on here? Maybe I'm missin' somethin' that's right in my face, haha, it happens. So basically you laid the 150 on it and just left it for a couple minutes beatin' the sh*t outta it?
Old May 18, 2004 | 04:57 PM
Mr_CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find these archives? Are they on here? Maybe I'm missin' somethin' that's right in my face, haha, it happens. So basically you laid the 150 on it and just left it for a couple minutes beatin' the sh*t outta it?</TD></TR></TABLE>
When you search, click on "archived" .. that's the archives.
I used an impact gun at my brother's house. He's got a craftsman 150psi, 30 gallon compressor. I was beating on it at a lower psi like 90 or so, but it wasnt going anywhere, so I just went ***** out and cranked it up to 150 to see how it'd do. I would put it on there and just beat on it until the tank lost pressure and had to recharge. Id let it refill and do it again. I did this like 3 times or so and off it came.
Old May 18, 2004 | 05:23 PM
JokerTypeR's Avatar
I appreciate it, I'm gonna try that method again tomorrow. I've got a 110 gal 160psi tank goin' at this. yeah, it's big. And a crafstman impact with no extension and I've still got nothin'. Again, gonna re-try my methods. Maybe I'll get lucky. Does it need to go back on this tight?
Old May 18, 2004 | 05:27 PM
hondahans's Avatar
As long as the clutch is holding, leave it in 5th gear and get a huuuuge cheater/breaker bar. A good impact with high psi blasted repeatedly will probably work as well. The mojority of the d motors that I have touched, have faired well after a broken timing belt.
Old May 18, 2004 | 05:43 PM
JokerTypeR's Avatar
Default Re: Questions on busted timing belts... (hondahans)
Yeah, my baby's pushin' 196K right now
udog1125
Sep 14, 2016 03:15 AM
asdfqwer426
19
Mar 27, 2013 07:23 PM
Jester88Si
Apr 22, 2005 08:13 PM
volklude
Feb 18, 2004 10:54 AM
LL
Oct 15, 2001 04:40 PM
