Spoon Sports flywheel question...
Old May 17, 2004 | 07:46 PM
ITRFetish2000
Guest
Posts: n/a
Default Spoon Sports flywheel question...
Anyone know if the Spoon Sports flywheel comes with a pilot bearing and centering tool?
Old May 17, 2004 | 08:43 PM
Blazeone's Avatar
Default Re: Spoon Sports flywheel question... (OemOutfittedITR)
I dont think so, but if you are interested i have a spoon flywheel for sale.
Old May 17, 2004 | 08:59 PM
eg_type_r93's Avatar
Default Re: Spoon Sports flywheel question... (BlazeONE)
comes with pilot bearing but not a centering tool
B2FiNiTY's Avatar
It will grind upon startup.
Old May 17, 2004 | 09:20 PM
BlueR's Avatar
Default Re: Spoon Sports flywheel question... (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">It will grind upon startup. </TD></TR></TABLE>
get the toda
Old May 17, 2004 | 09:23 PM
B2FiNiTY's Avatar
Default Re: Spoon Sports flywheel question... (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">
get the toda </TD></TR></TABLE>
Definately
Old May 17, 2004 | 09:26 PM
T I F O S I's Avatar
ill vouch for the toda f/w i love it
Old May 18, 2004 | 05:37 AM
TODAwhore's Avatar
Default Re: Spoon Sports flywheel question... (goldeknug)
Grind??
Old May 18, 2004 | 08:21 AM
KF_S2000's Avatar
Default Re: Spoon Sports flywheel question... (TODAwhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODAwhore &raquo;</TD></TR><TR><TD CLASS="quote">Grind?? </TD></TR></TABLE>
Yep, USDM starter gear teeth doesn't play well with the Spoon flywheel gear teeth.
Old May 18, 2004 | 08:27 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Is Spoon FW the only one from Japan that would grind? I know that Toda and ATS won't. How about JUN?
Old May 18, 2004 | 08:29 AM
BlueR's Avatar
Default Re: (Wai)
JUN grinds also
Old May 18, 2004 | 09:57 AM
Big Phat R's Avatar
Comes with a new Honda bearing.
It will not grind if installed properly.
Mine has not ground/grinded in 4 years of ownership and hard track driving.
Old May 18, 2004 | 10:05 AM
Tweakmeister's Avatar
Default Re: Spoon Sports flywheel question... (Big Phat R)
Get the Comptech AL, it's the lightest and it installs and runs perfectly.
Includes bearing already installed...I have a spare bearing if anyone needs one ($10 shipped and its yours)
Old May 18, 2004 | 01:28 PM
AssPenny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Big Phat R &raquo;</TD></TR><TR><TD CLASS="quote">It will not grind if installed properly.
Mine has not ground/grinded in 4 years of ownership and hard track driving.</TD></TR></TABLE>
I don't know about that... I installed mine properly and it ground with in a week of installing it. It got so bad that I would have to put the car in first, push the clutch in with my right foot, push the car with my left foot out the door and pop the clutch so the fly would move a little so it would start. I replaced it with an XACT and never had a problem since.
I've heard different stories from different people. Some say they have no problems at all, other say they have problems from the get go. I've also heard that there are 2 different versions out there. The old one which grinds due to the fact that the JDM starter bendix is different from the UDSM and another, newer version that works with both USDM and JDM. I have not seen any hard evidence to support the 2 version theory, so your guess is as good as mine.
Old May 18, 2004 | 01:30 PM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Spoon Sports flywheel question... (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">
it was a hella ash tray though
Old May 18, 2004 | 01:31 PM
AssPenny's Avatar
Default Re: Spoon Sports flywheel question... (RealTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">
it was a hella ash tray though </TD></TR></TABLE>
Hell yeah Still in my back yard, a little rusty, but it's still around. Used more as a drink table then an ash tray as all the ashes blow out with the slightest breeze.
Old May 18, 2004 | 01:56 PM
Mugen Type R's Avatar
Crazy ***** putting butts on a grindin spoon hella expensive flywheel while you coulda ripped some kid off on ebay
Old May 18, 2004 | 02:49 PM
mafay2's Avatar
New User
Check and see if u have a Denso starter, if you do, then good luck, there is a GOOD CHANCE that you will grind the starter occasionally and it will get worse if you don't fix it.
Old May 19, 2004 | 03:47 AM
TODAwhore's Avatar
Default Re: Spoon Sports flywheel question... (KF_S2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KF_S2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Yep, USDM starter gear teeth doesn't play well with the Spoon flywheel gear teeth.</TD></TR></TABLE>
My Spoon flywheel is 3 yrs old never gind since the day it went on.
Old May 19, 2004 | 10:08 AM
RagingAngel's Avatar
Default Re: Spoon Sports flywheel question... (mafay2)
If you're concerned..... but got a good deal...
find a buddy who drives an EM1 (99-00) Civic Si/SiR. Swap starters and away you go. ITR = Denso, SiR = Mitsuba. When you pull the starters and hold them side by side, it is evident they are different.
I did this when I got my Spoon Flywheel, which I ultimately ditched for a CM al unit that I'm loving more and more.....despite not having driven my R in over 6months now....
Old Jul 1, 2005 | 06:53 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: Spoon Sports flywheel question... (ITRFetish2000)
OK, who is using a Spoon flywheel, do you have this problem and how did you fix it?
Are we just putting different starters on? Are we getting JDM starters or using Ragin'Angel's idea?
There seems to be a way to adjust the starter slightly...has this solved the issue for us?
Old Jul 1, 2005 | 06:58 AM
Bbasso's Avatar
Default Re: Spoon Sports flywheel question... (George Knighton)
IIRC the CTR starter works well with that FW, But why bring this back from the dead to ask this?
Old Jul 1, 2005 | 07:27 AM
Mugen Mike's Avatar
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">JUN grinds also</TD></TR></TABLE>
It sure as hell does.
I would like to hear some more input on the subject as well.
Old Jul 1, 2005 | 07:41 AM
NiceDc2r's Avatar
Default Re: (Mugen Mike)
Get one of the Comptech flywheels. It comes in aluminum (7.5lbs) or steel (8.5Lbs) which can be easily resurfaced. Both come with installed bearings
Old Jul 1, 2005 | 09:13 AM
H-T Order of Merit
About 30 starts so far, and has worked every time.
I think I'll just not worry about it.
