NGK BKR6E-11 the same as NGK V-Power plugs?
Old May 17, 2004 | 04:43 PM
NickGSR95's Avatar
Default NGK BKR6E-11 the same as NGK V-Power plugs?
Like the topic says.. NGK BKR6E-11 the same as NGK V-Power plugs?
Thanks!
Old May 17, 2004 | 06:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: NGK BKR6E-11 the same as NGK V-Power plugs? (NickGSR95)
BKR6E-11's are V-power, meaning the electrode has a tiny v-shaped channel cut across the tip. I'm not sure exactly what it does, but it's there.
Old May 17, 2004 | 07:08 PM
Sack Master's Avatar
Default Re: NGK BKR6E-11 the same as NGK V-Power plugs? (PatrickGSR94)
The V-power is similar to a splitfire. Or at least it's supposed to be.
Old May 17, 2004 | 08:15 PM
Community Builder
Default Re: NGK BKR6E-11 the same as NGK V-Power plugs? (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">The V-power is similar to a splitfire. Or at least it's supposed to be.</TD></TR></TABLE>
V-powers are nothing like splitfires. The NGK V-power spark plugs have a single firing end, whereas splitfires have the firing end that splits into 2 separate pieces (Bosch +2's have 2 separate firing ends, and the +4's have 4 separate firing ends, but those are all junk ).
The V-powers have a single firing end like any ordinary spark plug, the name refers only to the groove cut into the end of the electrode.
xiaogou
Nov 21, 2007 01:37 AM
Nicks95GSR
Nov 30, 2006 10:42 PM
hybrid_vtec
15
Jul 30, 2004 01:37 PM
EL'ation
Aug 5, 2002 01:12 PM
