Idle continually goes up and down - help!
Old May 17, 2004 | 03:57 PM
92accordexdude's Avatar
Default Idle continually goes up and down - help!
I have a 92 Accord ex that now continually idles quickly up and down whenever the car is in park or nuetral. I've asked 4 shops and got 4 answers...anyone have experience here? I'm guessing the idle control value may need to be replaced, but one shop said there are two idle control values, one fast and one regular.
Old May 17, 2004 | 04:04 PM
secksiman19's Avatar
Default Re: Idle continually goes up and down - help! (92accordexdude)
my frinends 92 was the fast idle control nuclear reactor valve of confindence. replaced it from honder and it was all good to go
Old May 19, 2004 | 12:02 PM
tjohnson329's Avatar
Default Re: Idle continually goes up and down - help! (secksiman19)
could be no oil in the car...... check that out.
Old May 19, 2004 | 12:14 PM
cawamor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92accordexdude &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 Accord ex that now continually idles quickly up and down whenever the car is in park or nuetral. I've asked 4 shops and got 4 answers...anyone have experience here? I'm guessing the idle control value may need to be replaced, but one shop said there are two idle control values, one fast and one regular. </TD></TR></TABLE>
I had the same problem ('91 auto EX) and it turned out the idle control valve was bad. It was replaced and it's ok so far.
Old May 19, 2004 | 12:23 PM
fw190bvi's Avatar
Default Re: Idle continually goes up and down - help! (cawamor)
start with the basics........clean/replace ur air filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by secksiman19 &raquo;</TD></TR><TR><TD CLASS="quote">my frinends 92 was the fast idle control nuclear reactor valve of confindence. replaced it from honder and it was all good to go</TD></TR></TABLE>
WTF?!?!?!
Old May 19, 2004 | 07:59 PM
Default Re: Idle continually goes up and down - help! (fw190bvi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fw190bvi &raquo;</TD></TR><TR><TD CLASS="quote">
WTF?!?!?! </TD></TR></TABLE>
ok so maybe it was just the fast idle
Old May 19, 2004 | 08:31 PM
h22accordr's Avatar
my 91 ex was doing that too, but it was a vacuum line that was pinced closed up by the throttle body, id check the vacuum lines first the try that
Old May 19, 2004 | 08:35 PM
vc's Avatar
vc
did you say nuclear? lol
Old May 19, 2004 | 10:27 PM
DragonTLS's Avatar
does it do it when you start the car in the morning, if the rpm is erractic when the car is warm up, the idle control valve is bad
Old May 19, 2004 | 11:55 PM
typeR#0427's Avatar
Default Re: Idle continually goes up and down - help! (DragonTLS)
I have heard that you can just take off the IACV and clean it out really good and that usually solves the problem. It should be on the back of the intake manifold.
Old May 20, 2004 | 02:40 AM
repherence1's Avatar
does the car throw a Check Engine Light after u drive for a while?
my accord throws a Check Engine Light after i drive for a while. i checked the code and it threw an IACV and EGR code. but, i do not have a problem with my idle boucing up and down.
it could be that the idle is set too high. try adjusting the idle screw on the top of the throttle body--turn the idle down.
there was one occaision that i fiddled with my idle screw and set the idle too high...the motor would rev up to 1500 rpm then cut down to 800 constantly in park and in neutral. i turned down the idle via the adjustment screw and it was back to normal.
try making the adjustment, if that does not work, repost your results
i can ask my friend who is a honda tech at one the local dealerships what the problem may be.
k-ozz
Dec 25, 2008 08:58 PM
ALL-MTR-LSR
Honda Motorcycles
16
Feb 7, 2007 08:52 PM
2BDiesel
Sep 3, 2005 06:55 PM
Grandmasta
Apr 16, 2004 03:28 PM
relic_sypher
Nov 19, 2001 08:23 PM
