B16a Sir2 swap into EG??
Old May 17, 2004 | 03:43 PM
HATCHingMN's Avatar
Default B16a Sir2 swap into EG??
Whats the easier route,...its a 92 SI HB
I need help, I search but cant find what I looking for.
I want to know what ECU is easier/better to use in my swap b16a sir2 into my 92 SI??
I will be using my stock SI wire harness right?? but I'm not sure which ECU to use with?? p28 or pr3?? what about the wires on the injectors??
Any web page that might help me out with pics???
Old May 17, 2004 | 03:44 PM
Grip's Avatar
Default Re: B16a Sir2 swap into EG?? (HATCHingMN)
use a p28 or (what comes with the motor a jdm p30)
Old May 17, 2004 | 03:47 PM
Sliced Beard's Avatar
get a chipped p28 or a p30 ecu ecu and everything should be plug and play
Old May 17, 2004 | 03:51 PM
Grip's Avatar
Default Re: B16a Sir2 swap into EG?? (dirtyd463)
it dosent need to be chipped..chip it after you build the head..as far as the injectors..this is an eg man a 5th gen the injector clips on your si harness will just plug into your sirII injectors with no headaches..like some other chassis i wont mention....(cough) EF'S (cough)
Old May 17, 2004 | 06:20 PM
HATCHingMN's Avatar
Default Re: B16a Sir2 swap into EG?? (Grip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip &raquo;</TD></TR><TR><TD CLASS="quote">what about the wires on the injectors?
use a p28 or (what comes with the motor a jdm p30)</TD></TR></TABLE>
is the ecu p30 same as pr3??
any good infos website out there, I can look up??
Old May 17, 2004 | 09:19 PM
zer0.'s Avatar
i agree w/ trip.....chipping an ECU is pointless,for example upping the rev limiter is pointless because you won't make any power. use the p28.
Old May 17, 2004 | 09:25 PM
95civicSirCoupe's Avatar
USe the p28.. this is from some one that knows it cause my friend uses it on the same setup.
moejoepotatoe
Nov 26, 2012 01:38 PM
Xemu
Oct 18, 2006 04:29 AM
Fergy82882
Sep 30, 2004 02:04 AM
94CivSi
Feb 2, 2003 08:17 PM
creuger
Nov 3, 2002 06:15 PM
