TurboEDIT 2.0.10 (Try 10) Now Available
Old May 17, 2004 | 03:20 PM
TurboEF9's Avatar
Default TurboEDIT 2.0.10 (Try 10) Now Available
Downlaod the latest version of the TurboEDIT Engine Management system for both NA and Force Inducted vehicles, from http://www.TurboEDIT.org
Check the release notes for specific information on what was added to this new release.
Old May 17, 2004 | 03:30 PM
USDM 4G VTEC's Avatar
Default Re: TurboEDIT 2.0.10 (Try 10) Now Available (TurboEF9)
i dont wanna sound like a newbie
but can u link me to the step by step page on how u chip the PM6, or a pG7
i went to the ecu control page and pgmfi .com, but since is soo much to search, they havent made one yet for the OBDO as clear as the one for OBDI (ex uberdata)
i am still diggin info, but i want to also the link for the wiring on OBDO for the ecu control software,so we can datalog with turbo edit
i found it once, but now i cant seem to find it
Old May 17, 2004 | 03:45 PM
TurboEF9's Avatar
Default Re: TurboEDIT 2.0.10 (USDM 4G VTEC)
Here's an old old tutorial I wrote..
http://www.driftkids.com/index...6Chip
Old May 17, 2004 | 04:26 PM
Boosted Chemist's Avatar
Default Re: TurboEDIT 2.0.10 (TurboEF9)
hey how is the pr3 support coming, any plans for a FI mod so i can toss my vfac hack?
Old May 17, 2004 | 04:31 PM
Default Re: TurboEDIT 2.0.10 (Mad Chemist)
also i opened the stock pr3 map and hte high cam ignition map is wacky the timging jumps around from 1.3 to 55 back to 1.3
Old May 17, 2004 | 06:49 PM
xenocron's Avatar
The new TE supports VTEC...with boost!
Old May 17, 2004 | 07:06 PM
leed's Avatar
Default Re: TurboEDIT 2.0.10 (xenocron)
This newest version of TurboEdit deff. gets a thumbs up. Perfect transition into boost.
I have had the opportunity to run it in my car as well as a few friends, and all run very well.
Old May 17, 2004 | 07:34 PM
averageJoe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Chemist &raquo;</TD></TR><TR><TD CLASS="quote">also i opened the stock pr3 map and hte high cam ignition map is wacky the timging jumps around from 1.3 to 55 back to 1.3</TD></TR></TABLE>
yeah, i had the same problem, with several pr3 files. The high ign maps are all over the place, but the rest of the maps all look fine.
I am not a huge follower of te, but i do like to dabble in everything i can, so i am not sure if support for pr3 is continuing with this release. However if it is, there is a bug in the high cam ign map.
good work nevertheless
Old May 17, 2004 | 08:14 PM
TurboEF9's Avatar
Ya.. I clobbered the PR3 high cam addresses... Sorry.
There is a totally rewritten backend of this release which makes for snappier updates and such.
..anyway, I'll get it corrected, as well as apparently, I forgot to renable ROMulator support.. So.. two bugs for this release. YIPPIE! :D
I'll post when the new fix is ready.
Old May 17, 2004 | 08:20 PM
Joseph Davis's Avatar
Default Re: (TurboEF9)
Stunnariffic
Old May 18, 2004 | 05:13 AM
rioninja's Avatar
excellent
Modified by rioninja at 8:17 PM 5/18/2004
Old May 20, 2004 | 05:24 PM
xenocron's Avatar
Default Re: TurboEDIT 2.0.10 (rioninja)
Some screen shots for all you stunnas!
VTEC.....Yo!
Old May 20, 2004 | 05:32 PM
ATS*Mark's Avatar
OG triple OG
is this for obd0 ecu's only???
im interested in this or uberdata for my 00 ex turbo . id like some more info on this stuff how do you guys like it
Old May 20, 2004 | 06:08 PM
xenocron's Avatar
Default Re: TurboEDIT 2.0.10 (Hella_JDM)
Yes its for OBD0 ECU's only...
Old May 20, 2004 | 07:24 PM
ATS*Mark's Avatar
OG triple OG
thats homo , i dont want your buisness then
Old May 21, 2004 | 04:26 AM
xenocron's Avatar
TE isn't JDM either...so you are 0 for 2
Old May 21, 2004 | 05:20 AM
ATS*Mark's Avatar
OG triple OG
who cares if its jdm or not. oh you mean just cause my name has "jdm" in it?
thats original
Old May 21, 2004 | 05:31 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEF9 &raquo;</TD></TR><TR><TD CLASS="quote">Downlaod the latest version of the TurboEDIT Engine Management system for both NA and Force Inducted vehicles, from http://www.TurboEDIT.org
Whats Turboedit???
Old May 21, 2004 | 05:57 AM
kyle h.'s Avatar
Default Re: TurboEDIT 2.0.10 (tgreaves)
hotness
Old May 21, 2004 | 09:09 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">who cares if its jdm or not. oh you mean just cause my name has "jdm" in it?
thats original</TD></TR></TABLE>
Bro, I was just playing, not trying to be original...I saw your avatar and thought, "Hey, there's a way to increase my post count"
Old May 21, 2004 | 09:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">TE isn't JDM either...so you are 0 for 2 </TD></TR></TABLE>
I feel like Jason Parker has mislead me. I want to cry.
Old May 21, 2004 | 11:02 AM
JonnyCoupe's Avatar
Default Re: TurboEDIT 2.0.10 (J. Davis)
Ive been plying with TE 2.0 Try 9 for a bit, 10 looks v.nice how does the launch control feature work and what pinout is VTEC?
Cheers
Old May 21, 2004 | 01:29 PM
TurboEF9's Avatar
Hella_JDM,
"That's homo." ...you rock. :-\
...Launch control works based on VSS. Engaged under the user defined speed. (Normally tou want it about 6mph), disengaged anywhere after that.
And yes, you can still burn out with it.
... VTEC pinout is same as PR3.. VTEC activation wire is pin A8.
Old May 21, 2004 | 02:23 PM
ATS*Mark's Avatar
OG triple OG
turbo edit isnt homo , its homo that i cant use it cause it looks good.
Old May 21, 2004 | 02:51 PM
TurboEF9's Avatar
Default Re: (Hella_JDM)
Ah, OK. :D
Have you tried Uberdata? Blake's done a nice job supporting OBD1 and tuners have boasted some MAD hp numbers with it.
