B20 VTEC head gasket
Old May 17, 2004 | 01:42 PM
Pandahatch's Avatar
Default B20 VTEC head gasket
I have the Golden Eagle VTEC conversion kit on my B20B and it's working great. The headgasket though is leaking in the corners. Everything was torqued correctly using ARP studs. I have head that it is better to use the B20 head gasket instead of the Golden Eagle which is a B16 (P30) head gasket modified to 84mm. Which is better? Stock or modified. This oil leak is pissing me off.
Old May 17, 2004 | 03:55 PM
torr's Avatar
Default Re: B20 VTEC head gasket (PandaHatch)
i don't know which one is better but, i have an oem honda b20 headgasket and it doesn't leak at all
Old May 17, 2004 | 07:20 PM
Pandahatch's Avatar
Yea, I'm gonna put a new gasket. Iguess I'll use a factorey OEM B20B gasket. Do you need to modify it all if you're using the Golden Eagle dowel pins.
Old May 17, 2004 | 09:26 PM
Pandahatch's Avatar
bumpage
turbo90a
16
May 15, 2025 08:18 PM
Civic483973
Jul 11, 2010 12:57 PM
BILLY_BLING
Sep 28, 2006 04:44 PM
mh
Dec 14, 2003 11:22 PM
