Who has installed the Hondata Intake gasket ?
Old May 17, 2004 | 12:53 PM
The Ace's Avatar
Default Who has installed the Hondata Intake gasket ?
OK guys, I'm thinking about getting the Hondata Intake gasket:
http://www.hondata.com/heatshield.html
I have located a dealer in Europe who currently has the gasket for the B16A in stock, and I was wondering if anyone of you has it in his car, and what is his impression/opinion about it ? I know that it actually does work, and lowers the intake temps quite a bit, but what do you think ?
I think that this is probably one of the best bang-for-buck mods out there for ANY car......
Old May 17, 2004 | 03:48 PM
sohcfreak's Avatar
Default Re: Who has installed the Hondata Intake gasket ? (The Ace)
works great on my d16...A+
Old May 18, 2004 | 11:48 PM
The Ace's Avatar
Default Re: Who has installed the Hondata Intake gasket ? (sohcfreak)
So, out of the tenths of thousands of members with Hondas in here, just one person has installed this gasket ?
Doesn't bode very well for me.....
However, in theory I think that for 50 bucks, it's one of the best mods you can do to a Honda....
Modified by The Ace at 3:54 PM 5/19/2004
Old May 19, 2004 | 01:06 AM
B2FiNiTY's Avatar
search and yee shall find many users liking the gasket.
Old May 19, 2004 | 04:55 AM
88crxvtec's Avatar
Default Re: Who has installed the Hondata Intake gasket ? (B2FiNiTY)
I used it when I put an AEBS Manifold on my b16. I found that after driving for a while the intake was cooler. However if your in stop and go traffic the manifold will be heat soaked unless you have a vented hood. At the track if you stop and open your hood after each run you can keep your intake temps down, which was a great deal for my turbo setup. Most people use them when then change intake manifolds but pulling your manifold off just to put one on is not really worth it.
Old May 19, 2004 | 05:52 AM
crx_88_si's Avatar
you took all the coolant lines off the intake as well right? otherwise you're not doing anything different.
Old May 19, 2004 | 09:33 AM
88crxvtec's Avatar
Default Re: (crx_88_si)
I removed all coolant lines, I also am going to be putting on a Holley TB soon.
Kr4nG
Apr 4, 2008 12:06 AM
Mac
Jul 20, 2005 09:12 PM
18gsir
Aug 31, 2004 05:42 PM
euroturbo-R
Aug 12, 2002 12:34 PM
ImportHatch
May 24, 2002 06:54 PM
