Over heating
My 94 Accord kept on overheating slowly at idle after an hour drive. since I already have a new radiator and water pump installed, when I check the reservoir it filled back up full...
, i need help
Hoa T
, i need helpHoa T
I had the same thing happening to my 96 Accord. It turned out to be my condensor fan motor was out. I'd check both the radiator fan and condensor fans by running jumper wires from the battery to the fan to make sure they're not burned out. I just fixed mine this weekend. Running fine now. You can also test each fan by disconnecting the fan switch plug and running a jumper across the connectors of the plug. The fan should kick on if its good. Good luck.
