O2 sensor wiring help
Old May 17, 2004 | 10:46 AM
pyrojeff's Avatar
Default O2 sensor wiring help
I recently purchased a universal o2 sensor, however it came with no instructions, so I do not know which wires connect to which.
The engine harness had 4 wires, and they were orange/black, yellow/black, white/red, and green/blue, and they matched up with black, black, white, and green on the stock o2 sensor, respectively.
However, the color of the wires on the new o2 sensor are black, white, gray, and gray. Any help on figuring out which wires to connect would be appreciated.
Old May 17, 2004 | 10:53 AM
wickedEFguy's Avatar
Default Re: O2 sensor wiring help (pyrojeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyrojeff &raquo;</TD></TR><TR><TD CLASS="quote">I recently purchased a universal o2 sensor, however it came with no instructions, so I do not know which wires connect to which.
However, the color of the wires on the new o2 sensor are black, white, gray, and gray. Any help on figuring out which wires to connect would be appreciated.</TD></TR></TABLE>
I would gues this...
both the greys = regular blacks on O2 sensor heater circuit control to A6 and O2 sensor heater circuit power to A25/B1 (or any other good switched 12v source)
White = white - O2 sensor signal to D14
Black = green O2 sensor signal ground to D22 (or any other good ground)
I hope this helps and again this is what I'm assuming
Old May 17, 2004 | 11:24 AM
pyrojeff's Avatar
Default Re: O2 sensor wiring help (wickedEFguy)
Thanks... can anyone verify this information?
Old May 17, 2004 | 02:01 PM
Hawkze_2.3's Avatar
If it's a Bosch Universal, I can give you the diagrams....
Old May 17, 2004 | 06:30 PM
pyrojeff's Avatar
Default Re: O2 sensor wiring help (Hawkze_56)
It's an NTK (NGK).
Nuke209
Jul 6, 2006 05:47 PM
accrdpusha
Sep 16, 2005 04:09 AM
Mentat Ghola
Apr 11, 2004 10:58 AM
NonovUrbizniz
Oct 16, 2003 09:14 PM
